I recently got a Spec 3+ clutch and Fidanza Aluminum flywheel installed on my car at a local transmission shop. Ever since the installation it has been very hard to shift between gears. It takes a lot more effort to shift now than it used to. Getting it into reverse is the hardest... sometimes i have to use both hands and force it as hard as i can, and a couple times it grinded while going into reverse. When they installed the clutch they took the tranny out of the car and ran it without it in just to see if a ticking noise it had was comming from the engine or the tranny. It was comming from the engine but that is a whole different issue. anyways is this normal to happen after a clutch and flywheel install? What should I do?
May need to check it yourself or someone you know...
