  • SN95 4.6L Mustang Tech
Tuned 2Vs: What's your ignition timing at?
  • Thread starter Thread starter trinity_gt
  • Start date Start date May 20, 2007
trinity_gt
3,125
81
99
Canada
May 20, 2007
  • May 20, 2007
I'm not satisfied with my car's post-cam install power and am suspecting the tune. Although I've got time scheduled for a re-tune (with a different tuner) a week from now, I thought I'd do some forensics to see if my current tune is suspect. I dusted off the old AutoTap scanner and did some logging with it on some deserted country roads, accelerating hard in a few gears and cruising, logging a number of parameters including O2 sensor voltages and ignition timing. What I'm seeing is this:
- oddly, the throttle angle indication reads 19.6% when the throttle is closed. At WOT the indication is 92.9%
- oxygen sensor B1S2 always reads 0mV though I never see an MIL... The B2S2 sensor reads more normally though its indication makes me suspect that the Magnaflow hi-flow cats in my MRT-H are not so good no more.
- during steady state cruise at a couple-thousand RPM, the indicated spark advance is somewhere over 40o. In one log I see 45.5o...
- during periods of WOT, the ignition timing drops down to about 20o and begins to climb as the RPM rises. However, it only climbs to about 23o, maybe 23.5o maximum
- during these WOT runs the front O2s both saturate at 960mV (I also suspect it's running as rich as hell on the current tune...)
I'm most interested to hear what other tuned GTs are running for spark timing under these conditions. With my previous, pre-cam mail order tune, I'd get some tip-in detonation (even with 94-oct Sunoco) if I punched it in 2nd gear at, say, 3500RPM, indicating perhaps slightly too aggressive timing. Now I never hear any such indication. I actually wonder if the values above are closer to factory timing values rather than a properly done tune.
the98stang
2,408
Clovis, CA
May 20, 2007
  • May 20, 2007
20^ is kind of high. I would drop it maybe 2^. Just watch out for detonation.
trinity_gt
3,125
81
99
Canada
May 20, 2007
  • May 20, 2007
Keep in mind that this isn't initial timing. This is PCM-commanded "total" timing. With KOEO (key-on, engine off) I believe the spark advance value shows 10o if we can consider that to be the "initial" value.
As noted, during part-throttle cruise, the thing gets a ton of timing -- like 45o. At WOT though, the datastream shows the timing dropping to 20ish and then slowly climbing for the duration of the WOT to perhaps 23.5o, and that's it.
To me that seems a little low but I was hoping to compare to other guys with tuned 2Vs that have logged their spark timing at WOT.
blkhorse
345
May 20, 2007
  • May 20, 2007
N/A , I would have thought the timing should be around 32 to 36 deg at wot
hotmustang331
2,967
Bastrop,TX
May 20, 2007
  • May 20, 2007
Alot of cobra guys are pulling 20-22 *s of total timing. My car is running 15*s total. So yes yours sounds VERY low. The new tuner should fix you up I hope!
trinity_gt
3,125
81
99
Canada
May 20, 2007
  • May 20, 2007
Sorry...can you clarify?
According to the PCM datastream, I'm seeing 20-24o of total timing at WOT.
Are you refering to initial timing with the numbers you mention, such as when someone has a Steeda T/A and sets it to 14 or 15o?
DBMSTNG
I fantasize about it being BIG!
2,120
not quite here
May 21, 2007
  • May 21, 2007
he's talking about his turbo car. forced induction cars run much less timing than n/a cars.
the max allowed timing in the 2V 4.6L stock is 26* at 6000rpm at full load. now that doesn't take into consideration any timing retard controlled by collant temps, air temps, or exhaust temps.
i wouldn't trust the narrow band O2 sensors to tell me if i'm running richer than i'm supposed too. they are really only designed to be accurate at lambda.
reeber
574
26
38
Berlin, NJ
May 21, 2007
  • May 21, 2007
For comparison, I am blown with 15 pounds of boost and methanol injected. My timing is set through the computer at 18o...
When I was N/A I was at 24-26o....
  • Gulftown980x
  • Jul 29, 2026
squeak93
VE Table Not Dialed? Send Me Your Datalog.
  • X-cam34
  • Feb 8, 2026
  • Digital Self-tuning Forum
  • 2 3
2K
Digital Self-tuning Forum May 1, 2026
X-cam34
Free VE Table Corrections — Drop Your MSQ and a Datalog, I'll Do the Rest
  • X-cam34
  • Apr 12, 2026
  • 2 3
2K
Digital Self-tuning Forum Aug 26, 2026
X-cam34
SURGING IDLE / NO IDLE CHECKLIST FOR 1999–2004 MUSTANG GT (4.6L 2V) - Work In Progress
  • Noobz347
  • Aug 30, 2025
1996 - 2004 SN95 Mustang -General/Talk- Aug 30, 2025
SURGING IDLE / NO IDLE CHECKLIST FOR 1996–1998 MUSTANG GT (4.6L 2V) - Work In Progress
  • Noobz347
  • Aug 30, 2025
