MyFordsFly
- Oct 29, 2001
- 151
- 1
- 18
Most well tuned H/C/I 5.0’s should actually get better mileage than a stock 5.0, assuming the cam isn’t overly aggressive. With the better flowing combo comes a higher VE of the engine itself. One thing to keep in mind is that many running a n/a h/c/I package are also running a numerically higher gear ratio (often 3.73’s or higher). The gears can have a huge impact on fuel economy.
My 5.0 gets an average of 24mpg on the freeway….and can get upwards of 28mpg if I really baby it.![]()
Well V.E. is actually more of a measurement in making power although I do know it can be applied loosely to an engines overall perfromance to some degree. The bottom line is you will always have more overlap in a decent n/a performance cam and this will always yield worse mileage overall.
For instance listening to a performance cam at idle. Im sure you know that rough bumpity bump is actually slight misfires and you will generally have a good amount of fuel smell with a decent cam which is wasted fuel. So theres a huge loss of efficiency right there. And if you make an engine able to make more power higher in the rpm range (which is how you get the extra power from the increased flow of the new parts) its efficiency will always suffer down low. This is just common sense.
But anyway im not going to shoot ducks with you here. I have done many HCI set-ups in my years working at perfromance shops and have yet to have a customer come in and say "hey I actually have better mileage than before". It just rarely works out that way.
And your point of gears is a valid one. Although most people do gears before they do anything else. I do have to say Im having a hard time with 28 mpg with a hci 5.0 especially considering you probably also have gears. But I cant prove you wrong so thats all Ill say on that.
I will say this. If someone wants to do a 2.3 turbo car for mileage and they think it will get a ton better than a comparable 5.0 then your kind of wasting your time. Will a stock 2.3 turbo car with the boost turned up, a front mount, and exhaust get better mileage than a 5.0 that can keep up with you? Without a doubt. Will the difference be life changing? Not at all.
Yea because converters only flash right off idle.
