turbo guys get in here!!!!!!!
Mr. Rustypwnz
Advanced Member
Jun 1, 2005
1,761
63
69
indianapolis/ valdosta ga
ite im making a turbo kit for my vert, im set on it, I need something fast lol. ok so what turbo are you running? I want something that will be fully spooled about
2500-3000. ill keep it about 8psi, anyways, what maf sensor are you using? im looking at a pmas blow through. and then how is driveability? I know this depends on the combo, but lmk.......
thanks josh
this is what i was running but i realized it was too small and i would never see
1 million H.P.
so i upgraded to this. and a 3 foot charge pipe a better intercooler for a total of 500 psi of boost. i still did not obtain my 1 million hp goal so i swapped on a set of flowmster mufflers a cobra intake and made 999,890 so im close enough. these numbers are at the wheels. so im a little over 1 million at the crank
and i still have the stock block. its all in the tune.
3835409245
sorry for this pic. its a cell phone pic. LOL:rlaugh: :rlaugh:
here is the dyno chart with a penny to prove its real.
lmao, you have no life keith....
Anyway when are we hittin reynolds?? Josh do you want single or twins? which hot side are you going to use? Homemade coldside?
I got to get back to work on my car. I am swapping out the H for my catted one... damn emmissions
im going with a single, twins look like ass to me on a fox, plus it will be easier to run charge piping and mount the ic, should be around 380-400 at the tires, but first I have to sell my gt's lifeless shell then go to work, it might take a month or so, to get funds and get it all welded, I have a mig so it shouldnt be a big deal then grind all of my nasty welds down and then have then ceramic coated down the road when money permits.
I'm running the HPT60 street turbo kit and by my sig you can see the #'s, it is in full boost 3000 to 3200 rpm., running on a stock A9L , very streetable have put about 25K miles on the kit in 4 years. If I could scan I would put the dyno sheet up, I'll try to get someone to do that. Hope this helps. Here is a pic of the snail
Be glad to give you more input.
i have a 70 mm turbo. i see boost by about 2000-2500 rpm. i'm running a pro M mass air sensor. invest in a turbo blanket, it cuts underhood heat down ALOT. it will be as driveable as you want it to be, get a tweecer and good tune and it will be great on the street
