Tweecer Unit
Titan2175
23
Im planning on putting a Tweecer unit in my 94 GT, along with the unit im planning to put either 10.5:1 or somewhere around 9.5:1 pistons, does anyone know if the Tweecer can take care of the pistons and have the car be driveable and perform well.
Also with this im planning on moving up to 24 LB injectors, is the Tweecer able to take care of the injector change without changing the MAF sensor or is a recalibrated MAF needed reguardless of the Tweecer?
Is there anything major that the Tweecer is not able to deal with? If so what?
Any info would be awesome,
Thanks,
Erik
The TwEECer is an awesome "chip/programmer" that can handle all of your needs. You can alter/adjust just about everything. But it is not....shall we say, "user friendly"..as I am finding out right now. Be preparred to learn a LOT about the Ford EEC. The TwEECer is great because you can make easy, novice type changes. Then, as you learn, you can start really getting into the heart of the PCM and understand how certain things effect other things.
I am completly green when it comes to the TwEECer, but even with the basic knowledge I have, I have noticed great driveability problems that I was able to solve. I have a mild setup, as seen in my sig. The first things I did was to load my Pro-M 24 MAFS table, change my injector size, and eliminate my EGR and Thermactor. The first thing I noticed was my idle. I was able to lower my idle to a more "normal" level, and the engine doesn't surge like it did. Then I noticed, I used to have a problem where I couldn't drive through a parkinglot at low speeds without the car bucking. I was either in 1st gear at 3kRPMs, or I was in 2nd at 1500, and the car would buck. Now, I can cruise in 2nd at 1500rpms and the car rides smooth.
The thing I was not expecting when I first installed my TwEECer was how unfriendly it was for novice users. Then I remembered that tuning your car isn't really a novice type of thing. You need to research and read a TON.
Check out:
http://eectuning.org
http://www.freewebs.com/vristang/
Both great places for info.
You will want to get the RT version, so you can datalog...and you will want to get a WideBand o2 sensor, such as the LC-1...found here...
http://www.innovatemotorsports.com/products/lc1.php
Also the EEC Analyzer is a great program that helps do a lot of the math for you. A must for a novice tuner, in my opinion.
http://webpages.charter.net/eecanalyzer/Tuners.htm
Like I said, I am a complete newbie when it comes to the TwEECer. I haven't begun to scratch the surface on what it can do. But I love learning...and there is a LOT to learn.
I haven't checked it out yet, but I plan on buying it this week. There are a few Ford EEC tuning books out there that help teach you the ins and outs of the Ford EEC.
Like I said, there is a lot to learn, and don't get discouraged when you run into walls. It is not a simple program that you simply plug in, move a few dials, and it does the rest. This is a highly hands-on type of program, and it has a steep learning curve, depending on your understanding of tuning.
When you start doing searches, you will not find a lot of simple answers...as I am finding out now. Not because of bad information, but because there really are not a lot of novices out there. Like anything, if you don't understand it, it doesn't matter how simple someone tries to explain it to you....it still won't make sense.
At least that is what I am finding out right now. I keep thinking there is a simple answer for something, like I am expecting someone to say "change X to Y and Z to R", but it isn't that simple. Every car is going to require different changes to the EEC, so there are no simple answers.
All in all though, if you like learning something new...like I do...and you want to be able to change anything a chip can do, and more. The TwEECer is exactly what you want.
You figure you will spend a good $800-$900 on the TwEECer, EEC Analyzer, Wide Band o2, and maybe a book or two. But in the end, when you figure it all out, you will save a TON of money. Instead of paying for a few dyno pulls and having a custom chip..then changing something on your car and having to go through the same process again. You will have complete control with your laptop.
The short answer is, YES. The TwEECer should be able to do everything you want it to do...and more.
Sorry for rambling, I just thought I would share my (limited) experience.
Your setup is very similar in many respects to mine and it seems like if its working so well for you that it would solve all of my problems, thank you for all of this information, it will bbe a great help
Erik
Fett - Your starting to sound like a tweecer addict :eek:
It does get fun doesn't it :nice:
Titan2175 said:
So will i need a recalibrated MAF or should i be able to recalibrate the stock one to the 24 LB injectors do you think?
No need to recal the MAF when using a tweecer.
As a sn95 owner you have a great resource here on stangnet.
The 94-95 5.0 forum has a subforum for tuning.
It will be beneficial for you to hang out there, as there are some differences between the fox and sn-95 puters.
Good Luck,
jason
