TWEECER VS. FMU??
  • Thread starter Thread starter CONCRETEWARFARE
  • Start date Start date Sep 1, 2008
C
CONCRETEWARFARE
208
NEW YORK
Sep 1, 2008
  • Sep 1, 2008
I have been having so much trouble figuring out how to use the tweecer properly so I have been calling shops to see if they would do it and they all say to get rid of the tweecer and use a 4:1 fmu and msd btm. I have these parts so its not a problem but was wondering what everyone else thinks. I dont understand how I would need an fmu since wot under boost I go to 10-1 afr. Any one have any opinions? I should have about 13lbs of boost.
bentley429
Banned
Nov 25, 2004
528
Connecticut
Sep 1, 2008
  • Sep 1, 2008
No clue why they would tell you to use a FMU and a BTM. Custom tuning is the only way to go. If you cant figure out the tuner get it tuned with something like a SCT chip and just sell the tweecer. Should be around $500 including the chip.
T
tonyjr9108
Trenton, NJ
Sep 1, 2008
  • Sep 1, 2008
I actually just had the same response. I just completed putting on a S-trim w/42lb inj. and was looking to get it dyno-tuned and have a chip burned for it. I called a very reputable Mustang shop and was told to NOT ditch the FMU and MSD 6btm. He told me he has lots of customers out there running this setup anywhere around 400 - 500 hp all the time with no problems.
C
CONCRETEWARFARE
208
NEW YORK
Sep 2, 2008
  • Sep 2, 2008
hahah thats exactly what I was told. He said to keep the two and he has customers with 4-500 hp. That was from more than one reputable shop that I had called also. Oh well. I guess I can keep messing with the tweecer until I figure out what the best way is.
9
90bluegt
592
  • May 5, 2009
If you have a Tweecer or tuning device and the engine is mechanically sound. Then tune the car with the device. IMHO an FMU and other things are ways around to get the engine running properly. With a Tweecer you don't need an FMU as you can tune the engine, same thing with MAF and injectors no more need to get "calibrated" MAF to injectors. Tune the computer to use the MAF and injectors properly and there won't be problems.
IMHO otherwise you are just tricking the computer to run and not "fixing" the problem to being with.
If your still having problems, then go to EECTuning.org • Index page and everyone there is more than willing to help. They will help you understand the tuning part, not give you a tune for your car. There is a learning curve with the Tweecer or QH or any of them that you do yourself.
2000xp8
SN Certified Technician
Aug 8, 2003
8,075
1,658
194
NJ
May 5, 2009
  • May 5, 2009
Tuning devices are overated on foxbodies, and for most combinations they are just not necessary.
Use the fmu and btm. Almost any good shop will tell you that.
5.0 mustangs ran fine without tuning devices for 15 years.
strtrcr50
Previously from Dirty Jerzey exit 7a
May 5, 2009
  • May 5, 2009
If you're running 10-1 under full boost, I'm not sure what you'd accomplish by putting on a fmu besides a non controllable fuel curve. As far as timing, to make it easy, disable WOT mode spark control(scalar z_wspksw) If you go this route, tune your spark in the sealevel and altitude tables.
FastDriver
I was uncomfortably high & wearing a helmet
Sep 5, 2001
6,235
2,940
224
Vass, NC
May 6, 2009
  • May 6, 2009
They are telling you these things because it's what they are comfortable with. Others are telling you to tune it because THATs what they're comfortable with. Methods are like A-holes... Everyone's got one and they all stink but mine... or something like that.
I personally prefer controlling it with a chip I can manipulate. I think FMUs make it harder for a fuel pump to pump the right volume, but you can add an in-line pump to make up the difference.
Chris
90lxcoupe
20+ Year Stangneter
Oct 7, 2003
3,596
350
134
May 6, 2009
  • May 6, 2009
FMU's are generally a band-aid for people that dont want to upgrade to larger injectors, they are basically a bandaid. and if your 10:1 at WOT you obviously have plenty of fuel so an FMU will do nothing for you.
Call a shop and get a chip burned and call it a day, or play with the tweecer and learn to use it yourself
9
90bluegt
592
#10
  • May 6, 2009
  • #10
Chris
Your right people either use or tell people what they are comfortable with, without a doubt.
It's funny that on the fox bodies that tuning isn't required, when on the newer mustangs tuning is required, they both run computers that control the engine.
You have a tweecer, you spent the money might as well use it. Once you get the understanding of the what it can do, you'll have the car running much better than with an FMU and I agree I'm not sure what the FMU or MSD BTM will gain you.
Again my personal opinion, but I had a friend that went the fmu route and such with quite a few mods on a 306 and it just never ran right (IMHO), either way to rich at idle and fine in the top end or fine at idle and way to lean at the top end. He said it ran great, I didn't get it.
Foxfan88
My Grandpa has great wood.
Sep 13, 2004
2,487
Miami, Ok
May 6, 2009
#11
  • May 6, 2009
  • #11
anyone who says to stick with an FMU and BTM over a custom tune/ tuning device needs to be drug out back and eviscerated.
custom tune in the EEC >>>>>>>>>>>>>>>>>>>>>>>>>>>>> FMU and BTM
Fuel Vortech Supercharger injectors
  • Dontknowchit
  • Mar 13, 2025
Fox 5.0 Mustang Tech Mar 8, 2026
from6to8
K
Resolved Weird sound coming from a freshly rebuilt 5.0L
  • karhoot
  • Jun 24, 2026
Fox 5.0 Mustang Tech Jun 27, 2026
Mac131
Forced Induction Total Timing under boost
  • Dontknowchit
  • Aug 27, 2025
Fox 5.0 Mustang Tech Aug 28, 2025
Dontknowchit
Forced Induction Bypass valve backwards?
  • Dontknowchit
  • Jun 25, 2025
Fox 5.0 Mustang Tech Jun 29, 2025
JD1964
Engine Felpro 9333 pt1 (with 8psi boost)
  • JD1964
  • Jan 14, 2026
Fox 5.0 Mustang Tech Feb 1, 2026
Qtrhrse23
