tweeter whistles with rpm of engine?
Jun 20, 2005
137
hey guys, my front drivers side tweeter has a high pitch whistle that follows the rpms of the engine. its a 96 gt with the mach 460. i removed it and put a known good one in its place and still have the whistle. it only does this when the engine is on, and no its not the supercharger :D im thinking it could be my new alarm i had installed last summer, the sound had started that fall. other than that i have no idea, id like to find something to wrap the speaker's wires with to rule out interference. any thoughts? thanks guys
I'd put money on the head unit being the problem. Pioneer's are know for developing this problem. Especially if you have removed the stereo without disconnecting the power.
it was the head unit, no more obnoxious whistle. i do however still have a low annoying hiss comming from both speakers, even with the volume turned all the way down. not sure whats causing that?
pioneers have a known pico fuse issue. when they blow you get really bad feedback or alternator whine. you can either ground the outputs on your cd player or try and get a ground loop isolator but those generally dont turn out too good.
