I'll be taking my car back to the track sometime in late August and now I have a trans brake and two step. Since my stall seems to "lock up" around 4100 RPM I was wondering what module I should run on my two step.
Right now I have a 3500 module in it and I have done a few launches on the street on my ET Streets and the result is I floor it on the brake and let off the button and it immediatley smokes the tires to 6600RPM, it grabs a little then I shift. I know at the track I am going to hook or at least hook much better than on the street. It is quite a spectacle leaving off the brake on the street.
My question is what is the ideal module to run or am I looking at a trial and error thing here? Do I want to run a lower RPM module to "flash" the stall or do I want to run a higher module to get closer to the lock up of the converter?
When I had my 2500 stall that locked around 3K RPM I was footbraking and hooking up really well at the track (1.59 short times). I am really hoping that the car will still hook so I can improve those 60' times.
I know I am a little ways off from going to the track but I figured I would go ahead and be prepared.
