I need something that'll help plant the rear better, I know LCA's will improve traction but what about the uppers? I've read that the stockers give the rear end better "articulation" and aftermarket uppers make 60' times worse, so therefore you'd only get'em for a corner carver.
the lowers def will help traction. the uppers however carry the "claim" of helping traction, but they mostly just help you launch straight. they are stronger and help keep the rear axle from swaying and moving back and forth and front to back. this does help handling also though. it tries to do two jobs at once. or you can just get a panhard bar for the side to side axle movement and a tq arm for the front to back axle movement. both jobs are what the uppers try to do, but fail under extreme driving.
