  • 1994 - 1995 Specific Tech
ugly pinstripe
  • Thread starter Thread starter jamez1502
  • Start date Start date Nov 12, 2004
J
jamez1502
Banned
Nov 6, 2003
135
Lakeland Fl
Nov 12, 2004
  • Nov 12, 2004
whats the easiest way to get rid of the ugly pinstripe running down side of car. without leaving the glue. and also is there a fuse under the driverside seat. got in one day ant it wont move at all.
GRGT1994
1,034
  • Nov 12, 2004
Why the F would someone put a pin stripe on a Mustang?
mo_dingo
20+ Year Stangneter
Aug 26, 2003
3,031
Tucson, AZ
Nov 12, 2004
  • Nov 12, 2004
Any kind of adhesive will be an extreme pain to remove and not damage the paint.
The best way is to first get a heat gun, or a blow dryer.
The trick is to remove the sticker and take the adhesive with it. It's not easy, and it will take several attempts. Start by heating the very end, then peal the sticker off a tiny bit. If the adhesive stays on the sticker, continue to heat the sticker as you remove it.
So, start at the drivers side of the car. Start at the front. with your right hand, heat the sticker, and with you left, peal the sticker off. You want to heat the sticker as your pull it off.
Be careful. You can actually melt the sticker if you apply too much heat. So either vary your distance from the sticker, or move the gun up and down.
If the adhesive stays on the car, put the sticker back on, heat it some more, then pull the sticker off some. Repeat until the adhesive comes off of the paint and stays on the sticker.
Also, you will need gloves, and the heat produced will burn your fingers.
I have taken hundreds of stickers, pieces of scotch tape, etc etc off of RV's & cars. Be patient. Just be happy it's not scotch tape; that is a royal PITA after a couple years in the sun.
Scott
urban96
bubb rubb says:"woo woooooo"
3,464
Syracuse, NY
Nov 12, 2004
  • Nov 12, 2004
goo gone
OinkAodeOink
3,026
Daytona bch, Florida
Nov 12, 2004
  • Nov 12, 2004
its easy... Just let it sit in the sun all day, or take a heat gun/hair dryer to it, and slowly peel away.
On mine, sections would peel away easy, and then rip.. ide have to take my fingernail and finger and rub the shi* off.
The factory paint is very tough, so your fingernail wont damage the paint, if your worried about it.
Then take denatured achohol, or fingernail polish remover, to get rid of the goo left behind.
Then for a final detail, you can take rubbing compound, or polish to clean whatever was left behind.
J
jamez1502
Banned
Nov 6, 2003
135
Lakeland Fl
Nov 12, 2004
  • Nov 12, 2004
ok thanks for help i will try that tommorow. any idea on the seat its not a fuse in the fuse box i have checked them all
M
1996 GT Speedometer electrical nightmare
  • moon96gt
  • Oct 7, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 17, 2026
CAMTWO1070
D
Theft light staying on car starts right up
  • dtarang
  • Aug 13, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 15, 2026
dtarang
D
94 kill switch wire question
  • MrPerfect2
  • Dec 11, 2025
1994 - 1995 Specific Tech Jan 10, 2026
fasterthangas
F
Problems after exhaust install and 02 harness
  • djj62478
  • Jul 2, 2026
AeroCoupe
G
1995 Mustang GT- No PCM Communication, Runs Rich, Lacks power
  • gtrob
  • Aug 30, 2025
1994 - 1995 Specific Tech Aug 31, 2025
