Lyncher said:
^^ thanks a lot notch back...so in your first post are you saying not to go with a manual valve body? and pleas explain the thing about the shuffle and the clutch in lamens terms bc i do not really know what shuffle is or understand what that actually means. Thanks a lot
no , i'm not saying no manual valve boby...that is a GOOD thing to get.
it's just beacuse the aod has 2nd and 3rd all in 1 spot aka "D" you have to do the "shuffle" to manually shift w/out a manual valvebody.
w/ a man VB your good to go, manually shifting any other tranny doesn't hurt it, just the aod cuz the gear selection setup.
ford should have made d/od the same spot cuz it won't shift to od unless wot anyways. but thats what did, so thats how you gotta fix it.
the "shuffle" was explained, and the clutches i was referring to(if that was to me)
are the clutch packs and clamping bands. when you do the shuffle (holding 2nd by pulling back into "d")
the trans is in 2nd gear...but you re-engage clutches that are for 1st gear, because the shifter is pulled back to "1" so thats where the damage occurs...once you contaminate the fluid in an aod, particularly the stock converter...you cause the problems to multiply. automatically the converter needs replacing ($500 for stocker even so get a high stall....3000+) and the od band is a weak link too..wears out and that material is where??? the fluid , causing more failure yet.
that kit i mentioned b4 (motorsport wide gear set) is the same kit 5.0 t-bird guy is referring to, sounds like he didn't buy the kit, just the internal parts...i think the kit was about $500 when i did it , but that was over 6 years ago.
building an aod is EXPENSIVE.....if it's not a daily driver consider a c4 swap if you want to keep auto...but then you have no od...
i really like t5's better , but i have had some bad experiences w/ aod's as money pits that never performed. like i said...my '90 gt had 3 of them, and the last was on it's way out when i sold it. these were all done by done by trany shops too, so it wasn't my dumb@ss mechanics that screwed them up
but lentech makes a good product from what i hear......do like your doing..reasearch EVERYTHING b4 you have to do the work...so you know for sure what you want to do.
