  • SN95 V6 Mustang Tech
Unknown vibration :(
  • Thread starter Thread starter Aris
  • Start date Start date Jun 13, 2004
A
Aris
  • Jun 13, 2004
I own a 1996 3.8L V6 mustang. There is an unknown vibration that occurs when accelerating slowly. Also, it only happens between 30-50mph and when accelerating quickly, no vibration is observed. I had the u-joints checked and they are fine. Could it be a problem with the transmission? Please post your ideas and thanks for your time.
A
Aris
  • Jun 13, 2004
Here's some more info: the car currently has 76k miles on it and the transmission is automatic.....dont know if this will help but thought I'd add the info.
GREENBIOCH
1,241
In an Igloo
Jun 13, 2004
  • Jun 13, 2004
Check tire balance and wheel alignment.
stealthpony
48
Wood River, IL
Jun 14, 2004
  • Jun 14, 2004
i have a similer question my car shakes when i start it up not always just occacionally(i cant spell). what could it be?
SteveB
25
  • Jun 14, 2004
Do you feel the vibration in the steering weel or in the seat?
H
HitmanBob
  • Jun 14, 2004
I know
Ok two of my friends who had 96 mustang v6s had this shaking problem, and this is the reason that I was steered away (no pun intended) from buying this type of car. Its not the wheels. Its the transmission. When the transmission was going on their cars the car was shaky and it seems to be a common problem. The shakyness usually lasted a month or so..then the transmission just went on their cars. One of my friends actually had their transmission explode on them and the engine was damaged and there was risk of a fire in the engine. Get that fixed right away before somethign REALLY damaging can potentially happen.
high_racer
  • Oct 29, 2006
Hi there..
I had the same problem in my ex mustang 94 v6.
It's not from the transmission or something else.
It is from the Differential bearings.
Most of the second hand mustangs have this problem.
Today I own a 95 v8,I have the same thing.
Fixing this is not a big problem ,It is cheap.
So chill my friend.
Ford truck engine swap issues
  • keel
  • Jul 7, 2026
  • Other Auto Tech
Other Auto Tech Jul 13, 2026
General karthief
Drivetrain 8.8 Pinion and 302 rear main seal leaks after replacing. 93 5.0 with t-5
  • Steigy4827
  • Jun 23, 2025
Fox 5.0 Mustang Tech Apr 1, 2026
Steigy4827
Mustang II 4 cyl gear hunting and possibly messed up vacuum system
  • oesterreicher
  • May 31, 2026
1974 - 1978 Mustang II Talk & Tech Jun 14, 2026
manicmechanic007
M
01 mustang 3.8 fuel pressure issue
  • Mhaley2006
  • May 29, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 29, 2026
Mhaley2006
M
D
2.3l mustang hard starts and bogs and stalls when you floor it from idle
  • declan
  • Feb 19, 2025
  • 2.3L (N/A & Turbo) Tech
2K
2.3L (N/A & Turbo) Tech Feb 28, 2025
declan
D
