Upgrading 5.0
I just got a stock 5.0, except for exhaust, and I am going to have to replace the rear main seal. I was wondering since I have the tranny off what are some good upgrades to do. The car was sitting in the guy's garage for three years so that maybe why the seal is leaking. The engine only has about 60K so I don't want to a h/c/i change until something breaks. I have already done all the little things like a tune up and changing all the fluids. My ultimate goal is to get about 350hp and fast 0-60 times (power in the lower band). Thanks for any help.
I am using 3.73s. I do intend to have the wide ratio gear set in buy spring. With 3.73s it will work like 4.40 gear. My brother has 4.10s and from driving both I can say that I would be tempted to go 4.30. A low gear is your best friend with a aod.
I agree with shift kit, stall converter, AOD cooler, and a fresh gasket, filter, and fluid. Make sure you flush the cooling lines to the radiator. Most people forget that olds about a pint of old dirty fluid.
I would also replace the oil pan gasket. I did mine when the trans was out. I needed a clutch and trans rebuild...AND my oil pan started leaking right before, so it worked out good. Having the trans out was a huge plus.
I would also replace your water pump and T-stat. Pumps are cheap about 28 bucks at Murrays, and my 5.0L runs really cool after the new pump. The old one had some rust and corrosion around it, fortunately the rest of the cooling system was fine.
Yeah, mine is a convertible. So I will go with 4.10 gears. I heard from a guy at work an autos with a shift kit are better than manuals because the computer can shift faster than a human so that is why I went with an auto. Also is a shift kit hard to install. I have never been inside a tranny. From what I have heard I think I will take my car down to the shop to have the gears installed. I have done everything to an engine except rebuild it so I am mechinally incline. To answer SVT32VDOHC I changed all the hoses, t-housing, and thermo. The guy I brought it from said the water pump was about 9 months old. The temp was getting to 270 before I changed it but now it holds at 180-200.
While technically true, the gear ratios in the AOD suck ass.
The split second you gain in the shift is lost through poor ratios.
If you really want to stick with the AOD, look into a wide ratio gearset or maybe an 4r70w conversion down the road.
I have an AOD and have made my car pretty quick, but it will never compete with a well-driven 5-spd Mustang.
What shift kit? I'm guessing it wasn't a trans go. Or you didn't install the whole kit.
Car had all mods done when I bought it. No idea what type of shift kit, if there was one. I just fixed the front clip, painted it and sold it for profit. I put about 2,000 miles on it before I sold it though, so I had some time to play with it.
