- Jan 28, 2004
- 100
- 0
- 0
i installed a used pro chamber a hour ago. took the car down the road to test the new pipe out. took off pretty hard and smoke came out the tail pipes
you guys are prob shaking your head right now but i jus wanna make sure its from the pipe being used. the car the pipe came off of could have bad rings or valve seals causing the car to smoke. so, when i took off its jus blowing out that carbon that has built up on the inside walls of the pipes. im 100% sure my car didnt smoke b4 the pipe exchange.
it jus kinda freaked me out when i seen a big blue-ish cloud puf outta my tail pipes.
.you guys are prob shaking your head right now but i jus wanna make sure its from the pipe being used. the car the pipe came off of could have bad rings or valve seals causing the car to smoke. so, when i took off its jus blowing out that carbon that has built up on the inside walls of the pipes. im 100% sure my car didnt smoke b4 the pipe exchange.
