I know the input shaft is shorter.. Is it true that i can just use a fox body bell and im good to go?
Thanks for any help guys!
I didn't think I was going to need the adapter he built for his since his was originally an auto and mine was always a 5 speed. Did we do something wrong or are these WC tranny's different? I had some major issues with the tranny mount too. I don't know why this tranny is special but when I used to have a TKO in my car I only had to drill the holes on the crossmember to be a little wider, but this T5 WC tranny I got off my buddy's car (a 95 GT, though his was an auto conversion) we had to RIG a metal adapter because it was like 3" off line with my crossmember!I didn't think I was going to need the adapter he built for his since his was originally an auto and mine was always a 5 speed. Did we do something wrong or are these WC tranny's different?
In either case, you might beware of that. You will probably at least have to rheme out those holes like I did when putting my TKO in there (which is set up like the FOX's as far as input shaft and shifter location go.)
Oh yeah, and my buddy had the spacer on his but I chose not to use it on mine b/c there was plenty of the yoke that went into the tranny. So I have an extra UPR spacer if interested!![]()
You mentioned a metal adapter you had to make. A stock 94/95 5 speed car comes with a steel plate (exhaust hanger) that offsets the mounting points about an inch or so apart. You tranny mount gets bolted to the plate and the plate gets bolted to the tranny.
Even if what you say is true, and I'm not doubting you, I am still much further than an inch away from my crossmember. I'll have to shoot a picture and post it on here. I'll probably start a new post so that I don't hi-jack this one!
Put it this way, even fox guys have to modify their tranny crossmember to install a Tremec 3550/TKO tranny. Their crossmember slides back and forth after you cut the tach welds, we don't have that luxury. The mounting points are different between fox T5's and Tremecs.
FWIW I have a fox T5 in my car right now and my crossmember is elongated and I have that plate. Zero fitment issues!
as was said already, you can use the auto eec and the car will run. it just wont run right. the only way to make the auto eec function properly is with a tuning device like a tweecer or custom chip that has the functions of the automatic transmission disabled.Hey guys! I'm thinking of doing this swap as well. I can get a kit with all those parts you mentioned. Currently i'm running an auto and was wondering if anyone knew if the stock ECU has to be changed as well for the manual? and is there any kind of tranny harness invovled? Thanks
