Its not a filter its just like the filler neck tube open and connected to tbI don't think you can put a breather on valve cover. I think it messes with the pcv valve or something. I read about it somewhere but can't remember all the details. Someone smarter than me can provide answer to that.
Edit: I just noticed you don't have the valve covers with filler neck. You already have a filter installed in back of passenger side valve cover. I would imagine if that's working then all you need to do is plug off the TB and call it a day.
Ok so my pcv is hooked in the back top of lower intake to upper intake?,do i just run a tube with no pcv valve?,or plug it?,then just put open breather on valve cover?![]()
It's either all in or nothing with the pcv you shouldn't run the breather and pcv together . I am plugged with breathers on my vc . You must delete the line that goes from the throttle body to the valve cover or else it would be pressurizing the crankcase whether you run the pcv or not . The design of the systemax which I have read many other have the same issue makes the pcv draw oil into the intake path like a siv which is why I chose to plug it off and run open breathers.
Thanks im learning here...lol
Edit: just read it again and you already said you plugged it,so open breathers both sides then right?
