P Paulywalnuts446 New Member Oct 17, 2004 84 0 0 Aug 1, 2007 #1 Aug 1, 2007 #1 where do u connect the vacum tube from the brake master cyl. to the engine??, im runing a carbed motor. is it on the intake? do i have to put a fittin on? i have the edlebrock intake.
Mustang5L5 That is…until I whipped out my Bissell Mod Dude Feb 18, 2001 43,246 17,926 224 Massachusetts Aug 1, 2007 #2 Aug 1, 2007 #2 Brake booster vac line goes to the B/B port on the vacuum tree. On the carb there is a big fitting for the vacuum. You are supposed to rub a decent sized line from the carb to the vacuum tree as your source.
P Paulywalnuts446 New Member Oct 17, 2004 84 0 0 Aug 1, 2007 #3 Aug 1, 2007 #3 so i can just run it from my carb to brake booster b/c thats the only thing using the vac. i dont have anything else like ac/heat or anything
Mustang5L5 That is…until I whipped out my Bissell Mod Dude Feb 18, 2001 43,246 17,926 224 Massachusetts Aug 2, 2007 #4 Aug 2, 2007 #4 If that's the only thing you have, you can do that.
