Vacuum Leak...
  • Thread starter Thread starter GMstomper
  • Start date Start date Mar 3, 2004
GMstomper
71
Blackwood, NJ
Mar 3, 2004
  • Mar 3, 2004
OK I know I have a vacuum leak somewhere. Since I pulled her out for spring the idle gets erratic once its warmed up....but if I pump the breaks rapidly it levels out. Anyone know of any particular lines that have a tendancy to crack or should I just start searching??
L
leakyfaucet
273
North Carolina
Mar 3, 2004
  • Mar 3, 2004
The vacuum lines that run from the EGR and smog pump cracked in my car. I put them back together by squeezing a rubber vacuum line around both broken ends and pushing them together. I've heard you can use a vacuum line as a stethescope and just put one end to your ear and move the other end around the vacuum lines to see if you can hear a hissing. I've never done this though.
On another note, do you know where to get new vacuum lines for our cars?
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Mar 4, 2004
  • Mar 4, 2004
Disconnect the brake booster & cap the connection on the vacuum tree. See if that changes things. If it does, the brake booster or hose that feeds it is bad.
E
evrythingsux151
68
  • Mar 4, 2004
I think Jrichker has the answer your lookng for. You could just try pulling the raake booster hose and plugging it off, your brakes aren't going to work very well, but that will tell you if thats the problem. *golf tee's make a great vacuum line plug.*
GMstomper
71
Blackwood, NJ
Mar 4, 2004
  • Mar 4, 2004
Thanx for the help guys....I'll be sure to check them out tomorrow when I have some time tomorrow morning. Working mid shifts so I wont get home untill midnight...ughh
giddyup306
3,041
Mar 4, 2004
  • Mar 4, 2004
There is 2 easier ways. Spray carb cleaner around the vac lines. If the idle revvs up or smoothens out there is your problem. If you don't want to do that you can disconnedt the air inlet tube from the TB and plug it. If your engine still runs you have a major vac leak. You'll hear a hissing sound where your problem is comming from.
GMstomper
71
Blackwood, NJ
Mar 4, 2004
  • Mar 4, 2004
I'll try that too...I'm open to all suggestions
E
Chasing Vacuum leak 99 GT
  • EBNS_2005
  • May 2, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 3, 2026
X-cam34
Mustang II 4 cyl gear hunting and possibly messed up vacuum system
  • oesterreicher
  • May 31, 2026
1974 - 1978 Mustang II Talk & Tech Jun 14, 2026
manicmechanic007
A
Engine 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Today at 6:08 AM
DadLife0724
9
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
D
Engine 85 GT Backfires through Carb
  • DienstXIV
  • Oct 3, 2025
Fox 5.0 Mustang Tech Oct 7, 2025
85GTStangGuy
