Valve cover screws keep backing out.
GRGT1994
1,034
Any suggestions?
I have Twisted Wedge heads with the TFS valve covers, and cork gaskets from the HCI kit. The valve cover screws on the driver's side keep backing out. Last weekend I tightened em down pretty tight (took the upper intake manifold to get at em all). And they are already backed up.
Should I be using thread lock (aluminum heads), or longer screws? Does the gasket matter?
Thanks.
GRGT1994 said:
Any suggestions?
Thanks.
Try some loctite blue and see what happens. I don't see how it could hurt the aluminum.
I am trying to remember what is bad for aluminum, and I can't remember. So wait for some others to reply and see what happens.
Scott
I would just use some of those washers that have many points all around the outside to keep the bolts in place.
I use them on my fox vc's cause I had to use some regular bolts. It has all been good for almost 3 years now.
I would not want loctite on Aluminum threads ...... then again, I'm kind of old school about most things, lol.
Grady
94GTLaserRC said:
Grady...you mentioned the pointy washers, but I dont see where he even tried regular lock washers.
Also, I think a tiny thin bead of the gasket maker should do the trick also.
RC
While we are talkin Aluminum threads it might be good to bring up the fact that steel bolts in Aluminim threads can cause you to get that white junk that will corrode and yuck up the threads. It is because of the two different metals. The fix for that is simply a tiny dab of anti-seize.
The gasket maker would most likely keep the small bolts in place.
As always, more than one way to :banana: skin a cat :banana:
No offense to all of you :D cat lovers :D
Grady
Run a small amount around the threads then wind em in...Do the threads feel loose when you put the bolts in, like sloppy??? just curious.. Are the bolts at least 3/4" long?? More threads to grab means more bite.... :D
I thought I had a pic showing these somewhere and I found it :D
The center washer works great for keeping header bolts tight btw :nice:
Grady
They guy I talked with on Trick Flow's tech line said don't use thread lock, it will trash the threads. I picked up some lock washers, and am gonna give those a try.
