This one I do not understand. You do not pick up psi just running through a cooler. Actually you will loose some if running any sort of IC or AC. The air will be denser, because the charge is cooler, but this will not change the actual amount of air flow, so blowing the fuse (which obviously can't happen, but I understand your point) will not change anything in terms of air movement.
