I'm trying to diagnose the non functioning automatic transfer case on my POS Ranger. An explorer repair website says to use a VOM to check for continuity across two terminal in a pin connector. To check for continuity, do you set the VOM on Ohms and if there is no value, there is no continuity and if there is a value, there is continuity?
Also, they say to apply a 12 volt source to the pins on the motor side of the connector to see if motor will turn. Where would you get 12 volts from? I wouldn't think you would pull a wire off a 12 volt source on the vehicle, and I wouldn't think you should try to rn temporary wires off the battery. The easiest method I can think of is to wire two 6 volt lantern batteries together in series and run wires off that, but it still doesn't seem like too hot of an idea. Is there an easier/safer way?
