vortech??
JT929240
54
So a guy was selling a v-1 s trim for $2000 he just had it reconditioned from vortech he has the invoice to prove it it cost $750..I know the v-1 is the loud one and its an S-trim he was selling it with and 8-rib pulley which vortech says makes 8 to 10 pounds of boost...Vortech also said that this charger is capable of 20 pounds of boost??.. I know that the v-2 and v-3 are quieter and have self contained oil in the head units but whats the differnce between all the trims???
V1 and V2 are not self contained, they both get fed by the motor and returned to the pan.
The V2 is the SQ series which has a helical gear to make them quieter, all the V1 are straight gears, older technology and loud as hell...lol
The S is the largest street series blower they make, after that you can go T-trim which is the largest blower that will fit in that series bracket, while streetable not reallt ideal. They they have the YS, YSi, X and XX blowers...older units were A trim (smallest entry level blower replaced by the new SC, B-trim and R-Trim both phased out and replaced by S-trim) The differnce in the trims is the impeller size, the speed it needs to be efficent, the max speed of the impeller and max HP potential. They also have many otehr trims for smaller cars, G-trim, F-trim, E trim etc... http://www.vortechsuperchargers.com/scspecsheet.php
The amount of boost depends on your engine and what blower and crank pulley it comes with.
Thanks i was hoping someone could clear that up for me...lol......i am only trying to get around 450hp so i guess i'm good then with the s-trim...:nice:...Since the s-trim is the biggest for street how do you get the most boost out of it just by changing the pulley size because on vortech site the biggest pully i see is an 8 rib and i already have that?
Its not the rib of the pulley, its the diameter that increase boost...small blower pulley more boost, larger crank pulley more boost. You can play with the ratios to optimize your set-up, just don't exceed the maximum inpeller speed.
