water pump?
  • Thread starter Thread starter BYRDPE
  • Start date Start date Feb 27, 2011
BYRDPE
1,556
Memphis,Tn.
Feb 27, 2011
  • Feb 27, 2011
how can i tell if it is reverse rotation or standard? what are the symptoms of running a standard pump instead of the reverse rotation pump? i bought one a while back from a member and i assumed it is a standard pump for the 5.0l.
i just installed it last weekend along with a stant 180 stat and it appears when the car is at operating temp and i look into the radiator the coolant is just barely flowing from the tubes. the radiator tank on the pass side is extremely hot while the tank on the driver's side is warm to the touch. could a sticking thermostat cause these issues also?
btw...i am running a efan.
thanks
2000xp8
SN Certified Technician
Aug 8, 2003
8,075
1,658
194
NJ
Feb 27, 2011
  • Feb 27, 2011
Is the car cooling properly?
Does the heat work?
BYRDPE
1,556
Memphis,Tn.
Feb 27, 2011
  • Feb 27, 2011
heat works fine. i have my autometer gauge sender tapped into the thermo housing and it has been fluctuating inconsistantly. sometimes while moving the temps on the gauge will drop to read ~160 while the temps on my pms read ~195. i believe my thermo may be sticking as i didn't verify it prior to the install.
2000xp8
Aug 8, 2003
8,075
1,658
194
NJ
Feb 27, 2011
  • Feb 27, 2011
I'm not sure that's the best place for the gauge to be plumbed into.
If the thermostat closes it will read water that's just sitting there since coolant comes from the intake to the radiator.
I'd put the sensor in the intake where most people put it, you may need an adapter.
If the thermostat was sticking, likely the temp would rise substantially, then drop like a bomb when it finally opened.
Don't know much about the pms, but if it has it's own sensor and that's reading from the intake side, that could be why the temp is different when the thermostat closes.
BYRDPE
1,556
Memphis,Tn.
Feb 27, 2011
  • Feb 27, 2011
the pms reads off the ecu so i'm comfortable with my autometer in the thermo housing. its been there for over 10 years. there is usually a 10* difference between the 2.
i have verified the thermostat is definitely working. i put it in a pot of boiling water with a thermometer. i believe its a faulty pump because when i remove the radiator cap while the engine is at op temp there is very little water trickling from the flow tubes. my aluminum rad is about 2 years old and in great shape.
just went to napa and picked up a new pump. i'll post back with results once i install it.
thanks for the replies.
Wildstringer
65
  • Feb 27, 2011
I could be wrong , but I believe all HO 302's are reverse flow water pumps.
BYRDPE
1,556
Memphis,Tn.
Feb 27, 2011
  • Feb 27, 2011
yeah...but i'm questioning whether the pump i installed is a reverse rotation pump. i bought it on the corral over a year ago and i just installed it.
anyone have a diagram showing the directional coolant flow?
Engine Themostat
  • Mindseye007
  • Jan 30, 2026
Fox 5.0 Mustang Tech Feb 1, 2026
86HO5.0
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
O
2001 mustang gt overheating
  • orinsmiley11
  • Jul 17, 2025
1996 - 2004 SN95 Mustang -General/Talk- Jul 17, 2025
Fuel ‘88 GT Runs Rich Cold — Fixes Itself When I Unplug Sensors (ECT, MAF, O2, etc.)
  • Sufarry
  • Nov 6, 2025
Fox 5.0 Mustang Tech Nov 9, 2025
Mustang5L5
D
Resolved Upper radiator hose cold??
  • dqureshi06
  • Oct 31, 2024
2K
Fox 5.0 Mustang Tech Nov 11, 2024
limp
