how can i tell if it is reverse rotation or standard? what are the symptoms of running a standard pump instead of the reverse rotation pump? i bought one a while back from a member and i assumed it is a standard pump for the 5.0l.
i just installed it last weekend along with a stant 180 stat and it appears when the car is at operating temp and i look into the radiator the coolant is just barely flowing from the tubes. the radiator tank on the pass side is extremely hot while the tank on the driver's side is warm to the touch. could a sticking thermostat cause these issues also?
btw...i am running a efan.
thanks
thanks
