Way OT Explorer radiator
  • Thread starter Thread starter rd
  • Start date Start date Dec 27, 2005
rd
3,316
63
109
Ocean Springs MS
Dec 27, 2005
  • Dec 27, 2005
Does anyone know how to change the radiator in a 96 Explorer 4.0 v6?
We are on a road trip and need to change one. Most important, do I have to take the engine fan off? And if so, do I need a fan wrench, etc?
Thanks.
Busted07
I need my gorilla to be about an inch longer.
Nov 15, 2005
  • Dec 27, 2005
I have done this, and its one of the worst i have ever done. if yours has the tabs (look down the drives side, and see if there are 3 plastic tabs sticking out from the plastic shrouds that hold the radiator in) youll know what i mean when you look at it. i ended up having to cut the middle one off to get the damn thing out. i talked to several mechanics about it, and they all said the one i was doing was the worst. it has two plastic supports, one on either side and they make it a PITFA to get out. if thats not the radiator you have, shoudlnt be much to it at all. i removed the fan and shroud to make sure i wouldnt jack up the fins. took it to a radiator shop, had them reseal the tank, and reinstalled it. cutting that tab did nothing but make it easier to get it out & in. i noticed no difference support wise.
rd
3,316
63
109
Ocean Springs MS
Dec 27, 2005
  • Dec 27, 2005
Thanks.
This one was straightforward. We are in South Mississippi, and the closest we found the radiator was in Mobile. So we bought the radiator.
It was easy to change. I did loosen the fan, but I did not need to. Just move the shroud the back.
Pulled the hoses, the at cooler lines and off she came.
This one had two tabs at the bottom of the tanks for the shroud to sit in. I did break a tab on the pass side putting the new one in. Other side fit fine, and it will work just fine.
A big thanks to Rainbow Radiator in Mobile AL, for getting the radiator in 2 hours! And outstanding grilled sausage!
Busted07
Nov 15, 2005
  • Dec 28, 2005
Glad to hear you got it taken care of. Im not positive of the year of the one i worked on, but be happy it only had those 2 tabs instead of 3. I had to leave work early that day i was so mad.
J
Suspension Foxbody mustang Steering shaft issue
  • Jakub2537
  • Sep 5, 2026
Fox 5.0 Mustang Tech Sep 11, 2026
gkomo
M
Resolved 1988 Foxbody - Overheating Summer
  • MDrisc
  • Oct 26, 2025
Fox 5.0 Mustang Tech Jul 17, 2026
fasterthangas
F
9
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
Engine Motor swap from a 2003 Explorer
  • 1996mustang new
  • Oct 9, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 16, 2025
squeak93
Engine Suggestions on an engine rebuild. Stock cam/GT40Ps or aftermarket on both for a fun weekend driver?
  • MadSquirrelTech
  • Apr 28, 2026
Fox 5.0 Mustang Tech May 7, 2026
MadSquirrelTech
