weight reduction
Dash frame?
What exactly out of the dash is being removed? I know the metal for the steering column needs to be there... The only other thing I can think of is a little bit of metal in the middle where the radio is, and a strip to the passenger side kick panel area, but you kinda need that one to bolt the dash in?
Color me curious.
I am also in the process of weight reduction in my mustang. So far i have deleted the following.
A/c
Smog pump
Entire interior.
Front sway bar.
Hood latches ect.
Fiberglass hood.
All windshield wipers and accessories.
Any ideas for anything else? I keep hearing about the dog bone and quad shocks. Do these items need to be replaced with anything after they are off? Also , when the smog is removed do you need to cap the hard lines where the rubber ones come off of it ? I'm confused about what to do with them , I don't want any vacuum leaks. Thanks guys.
You shouldn't have any issues getting rid of the dogbone. I didn't notice anything different after I removed mine. The quad shocks help control axle windup. You can try removing them to see how you hook up. If you get a lot of wheel hop with them out, like I did, simply bolt them back on. Going to aftermarket control arms allowed me to remove the quads and not experience any wheel hop.
My GT hatch right now weighs 3150 with the roll cage. So far i have the following weight redux items:
All Smog Equipment
O/R h pipe
Alum Radiator
Rear seat/brackets/seat belts
Spare tire + jack
Sound deadening
i think thats it...but i could be missing a couple small things. I doesnt take all that much to get some weight out of these cars.
my full weight (everything, even spare tire)82' with a 30-40lb speaker box in the back weighed in at a trucker scale at 3250lbs, which i suppose isnt bad, my friends 79 cobra 4 banger(non turbo) hatch weighed in at around 3000lbs if i remember right..both had 1/4-1/2 tank of gas
~Mark~
