  • 1994 - 1995 Specific Tech
Weird engine temperature
  • Thread starter Thread starter ShiftTheDrift
  • Start date Start date Oct 29, 2005
ShiftTheDrift
365
Bakersfield, CA
Oct 29, 2005
  • Oct 29, 2005
We have an issue today where we've removed the aftermarket chip and now experiencing an overheating problem. However, note that when we turn on the AC/heater the engine begins to cool.
We've also preformed the poor-boys diagnostic and pulled, what we believe is code 33 (EGR opening not detected). For those who already know, during the "pre"diagnostic, the computer probes all the sensors and has shown the fan is working properly.
Something else more or less of subject, the car is running with the stock computer, an E303 cam, heads and so on with idle RPM around 850 with the IAC connected. I've never in my life seen a stock J4J1 computer handle an aftermarket cam and heads this well before.
It might have nothing to do with the problem at hand, but maybe worth mentioning.
Any ideas on the overheating issue? Thanks!
SeventyMach1
Keep it lubed .... keep it straight .... and keep
Mar 30, 2005
1,940
North Carolina
Oct 29, 2005
  • Oct 29, 2005
So the high speed fan is working properly?
I'd try to get rid of that code regardless. It doesn't sound relevant to the problem .... but you never know. It might save you from another problem down the road anyway.
Don 95Vert
1,091
Delaware, OH
Oct 29, 2005
  • Oct 29, 2005
The 'by the book ' diagostic procedure for a bad ECT sensor is to see if the fan comes on when the AC is on. Yours must be because it is cooling. I'd wager to say the fan is not coming on when the AC is off. Get a Ford ECT sensor. It's on the heater hose junction on the front of the engine - two wires.
Don
ShiftTheDrift
365
Bakersfield, CA
Oct 29, 2005
  • Oct 29, 2005
yeap, the highspeed fan is working. We've proved that when putting the EEC into diagnostic mode.
ShiftTheDrift
365
Bakersfield, CA
Oct 29, 2005
  • Oct 29, 2005
Don
Okay, in this case, you're right on the money. When we turn on the A/C the fan is on and doesn't turn off. As soon as we turn the A/C off, the fan turns off and remains off.
For all intents and purposes, we unplugged the ECT, started the car and the fun runs no matter what.
Does this help?
ShiftTheDrift
365
Bakersfield, CA
Oct 29, 2005
  • Oct 29, 2005
It just seems interesting that this problem has only presented itself since we removed the JMS chip. The programming for the chip indicates fan comes on at 185*. Perhaps the ECT was feeding the chip false readings or the chip was collecting engine temperature from a different source?
HISSIN50
34
129
Oct 29, 2005
  • Oct 29, 2005
You can use a meter on the ECT to note voltage and/or resistance (it has a thermistor). That is how I would do it.
Good luck.
Ford truck engine swap issues
  • keel
  • Jul 7, 2026
  • Other Auto Tech
Other Auto Tech Jul 13, 2026
General karthief
Engine Suggestions on an engine rebuild. Stock cam/GT40Ps or aftermarket on both for a fun weekend driver?
  • MadSquirrelTech
  • Apr 28, 2026
Fox 5.0 Mustang Tech May 7, 2026
MadSquirrelTech
Hard to start when engine is cold
  • 86_Capri
  • Mar 11, 2026
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 21, 2026
CAMTWO1070
Fox Xtremely high fuel consumption
  • PonyGTrider
  • Apr 11, 2026
  • 9 10 11
6K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 9, 2026
PonyGTrider
J
'96 Cobra: A/C gets weak and engine misfires under load when warm
  • jruhnke
  • Oct 22, 2025
  • SVT Tech Forum
SVT Tech Forum Nov 20, 2025
nickyb
