This won't be a ton of help, but I purchased what was supposed to be 15x10 draglites with 6.5" backspacing from ebay. I think they're actually 15x9 w/ 5.5" backspacing. I measured and that's what I came up with, but I need to remeasure. I measured 3 or 4 times, but I could have measured wrong, although I doubt it.
Either way, I have 275/50 BFG Radial TA's mounted on mine and they sometimes scrape in the back, but I'm not sure if they're scraping the outter fender or the inner fender on the back side of the tire. If I get my rear end sliding at all or go up an uneven grade at an angle (anything that causes the suspension to move very much basically), they rub.
I was able to keep my quad shocks without reversing them, but I did have to dent the casing a little. They're still functional. There are probably 50 threads about this, so do a search and you'll find tons of info on this subject. I don't think they'll stick out of the fender, but I'd bet you'll rub somewhere. Come to think of it, my tire may be rubbing on my quad shock. Many guys remove their quad shocks, but that's only recommended if you have aftermarket control arms as the quad shocks help control wheel hop. You can also reverse the quad shocks, but I don't think that worked for me for some reason. I can't remember...it's been a couple years
Again, do a search and you'll find loads of info
