Weld Draglite fitment question.
I just picked up some 15x8 draglites for dirt cheap for the rear of the car. What backspacing is normally run on these wheels? The wheels I bought are 4.5 inches of backspace and the rim looks like it sits nearly flush with the out fender well. Is this the correct backspacing? What size tires do you suggest? I dont want to have a redneck looking tire sticking out past the fenderwell..BTW the car is not lowered.
This is my 88 Gt with 4.5 inch baskspacing with 255/60/15s. It tucks right in nicely.I also have a set of 5.5 inch backspacing and will be trying them out soon.
Here's two pic's of my Cobra with Weld Draglites in 15x8 with 4.5" backspacing. The tires are 295-50-15's and do stick out about a 1/2 inch on each side. I did not roll the fender lips because I had already had the car painted and didn't want to ruin the paint or crease the sheetmetal. What I did instead, was to buy a rear airbag kit (Air lift) for $65.00 from Summit Racing to prevent the sidewalls from getting cut on the rear quarter panel lips. Although they stick out somewhat, I get a lot of compliments on the size and look.
Here's a pic of my twin brother's '85 GT with the same size tires and wheels.
dwhiskie said:
Both of those cars are very sweet. What size rims/tires are you running in the front?? I got skinnies and am looking to go a bit wider
Thanks! We're both running 15x7" (with 4.5" backspacing) Weld Draglites in the front. Our tires are different sizes though. He's running B.F. Goodrich Radial T/A's (225-60-15) and I'm running the same tire but different size (215-60-15) as I wanted my front end to be a little bit lower for a slightly different look.
Yeah, it's 4.5 backspacing, with 275/60s . I had to run a 1/4" spacer, otherwise I would have had to use the BFH on the inner fenderwells. No rubbing now, and that's a 28" tire.
Brandon
I had 15X8's with a 4.5 inch backspacing but I regreted it because they rubbed and stuck out. Here is a picture of it.
Unfortunately Weld doesn't make the "Exact" backspacing anymore for the Mustang. They either make an 8 with a 4.5 or 5.5 inch BS, when an 8 needs a 5 inch to sit just right. They did make the correct wheels for a while, they were called "XP's". I actually found a set of 16X8.5's with a 5.5 inch BS and they fit perfect. :nice: Here's how they fit with 245-50-16's Nittos.
WELLS PERFORMANCE 1347 University Boulevard Jacksonville, FL 32211 (904) 743-5878 is also a Great place to get Welds from. Even a little cheaper than Summit and with Great customer service. :nice:
Good Luck!
Good Luck!
What are the specs on the tires for the first pic?
