weld pro star help
BlackO3GT
54
I have a 2003 mustang Gt which im going to be putting some skinnys on the front and slicks for the rear. Now which backspace should i go with on each set? What tire sizes should i use for the front and back?
15x3.5 on the front and you will have to grind down the caliper and or the bracket not sure but as for the backspacing I am not sure. and for the back I would go with 15x10s and I am sure someone will chime in on the backspacing. and on the front you might have to use wheel spacers as well. Thats what my buddy had to do and he has a 03 Mach 1.
For a 99-04 you need a 7/16" spacer for the front. For the rear, a 8 inch wide wheel you should go with a 5.5" backspace, and a 6.5" backspace for a 10 inch wide wheel. Don't forget studs and lugs for those wheels. As for tire size it depends on the width of the wheel and height you want.
thanks guys. i have a eibach spacer in the rear it might be like 1"1/4 i forget lol but that might work for the front when i take them off the rear. As for tires i want to run a micky et street drag radial. for the front i dont care w/e fits
Anybody got pics of a 15x9 with 5.5 backspacing ??
