welding tank question
  • Thread starter Thread starter wicked93gs
  • Start date Start date Feb 13, 2009
wicked93gs
1,198
229
93
Nashville TN
Feb 13, 2009
  • Feb 13, 2009
I just bought a mig welder...but still need to buy a tank...how long does say a 40CF tank last? an 80? a 20? I'm new to mig welding...previously I have only done stick welding...I understand mig welding is much easier
10secgoal
2,801
San Diego
Feb 13, 2009
  • Feb 13, 2009
Hard to say really. Depends on the CFM you use when your welding, and if the tank has been used for anything else. A pure tank will last longer. I use 125's and 150's and they will last quite a while.
Mig is easier than stick for sure. No scratch starting, and not slag to break afterwards. But is not as forgiving with contaminants, and easier to blow through with. the wire pushes, so get it too hot, and bleh.
mustbereel
318
Escondido, CA
Feb 13, 2009
  • Feb 13, 2009
I say get the 125. I started with a 40 and got tired of having to get refills. Luckily Airgas gave me full credit for the 40 when I traded up.
wicked93gs
1,198
229
93
Nashville TN
Feb 13, 2009
  • Feb 13, 2009
well, i got it to install the mustang II front suspension...the welder says its good up to 1/4" and from what I just looked at in the kit, the thickest metal is between 1/8" and 3/16"...I guess my question is will the 40 last me long enough to finish the welds I need to install the crossmember? refills don't bother me as long as I can finish the planned work i will be doing each day(an hour of actual welding on a guess?)
10secgoal
2,801
San Diego
Feb 13, 2009
  • Feb 13, 2009
May cut it close, but may just be OK.
67rcks
373
Feb 16, 2009
  • Feb 16, 2009
go with a medium size tank, about 3 ft high 8" in diameter, you will need about 2 for complete restoration. avoid those 6' big tanks, too heavy to move around as it weights about 150 lbs full.
wicked93gs
1,198
229
93
Nashville TN
Feb 16, 2009
  • Feb 16, 2009
I did end up getting a medium sized tank after all
K
Door post and rust repair
  • Kleinjj27
  • Aug 21, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 27, 2026
Kleinjj27
K
P
Air Fuel ratio bung location.
  • Praetorious
  • Feb 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 11, 2026
Some exhaust welding help needed
  • limp
  • May 31, 2024
  • 2 3 4
8K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 29, 2024
General karthief
G
Intro and FB questions
  • gflat65
  • Nov 16, 2025
1965 - 1973 Classic Mustangs -General/Talk- Nov 25, 2025
horse sence
new :poo: box, may need to hit you guys up for 79-82 info when i fix thIs turd.
  • rednotch
  • Sep 27, 2025
  • 2 3
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 23, 2026
limp
