Well, hopefully thumpers will get me into the 12's now!!!
fastf50rd
720
mass.
It's about freakin time. I finally just buttoned up my s/c install. I have yet to rev it past 3500, i want to wait to get it tuned. Hopefully i'll be seein atleast 350hp. I'll post later with pics after i finish cleaning and painting everything nice. I have one question though, does the BOV have to shoot back into the inlet tube, or can i just have it blowing off into the engine bay.
If you blow it off into the engine bay than your car will be really rich when you let off the throttle. Just like the other guy said....It is already metered.
If you have everything installed in your sig than I think you'll be seeing close to 400rwhp maybe 380....That blower isn't quite as efficient as an s-trim but you do have decent heads and cam.... Should rip
Oh, i see now. How bad does a rich condition hinder performance? Besides using more gas what other problems would i see. Also, the BOV doesn't have to sit horizontal right? Cause i'm turning it down for better fitment.
Do you have a "blow thru" MAF or a draw thru? If its a blow thru, then yes vent the the BOV to the atmosphere. If its a draw through then it needs to go back into the intake tract, but after the MAF.
Yeah that is a regular style draw through meter. No problem though. Just attach a tube to the Bypass valve and put a grommet or something in the intake pipe between the blower inlet and after the meter. Attach the hose to it and you won't have any problem. If you blow it off to the atmoshpere it isn't a BIG deal but.... It will be rich between shift and may pop through the exhaust. You really just wanna do it right.
Any updates? I would also guess way over 350rwhp. And probably low low 12's/high 11's.
Matt
Yeah, i don't know what the deal is. It does run way rich, but i still expected sooooo much more. My new pinging problem has just pushed me to go with a big N/A setup. I really don't know what else to do with it. I've been through everything every mustang guru has suggested to stop the pinging. I'm pulling the vc's off tommorrow, because i must have a mechanical problem.
