• Community Forums
  • Regional Forums and Event Information
Went to Woodburn today
  • Thread starter Thread starter stevstum
  • Start date Start date May 28, 2005
stevstum
130
Salem, Oregon
May 28, 2005
  • May 28, 2005
I ahve only raced one other time and that was in my 89, which I saw was there racing. I am hooked and will be going up there on a regular basis. My first run was a 14.96 @ 98.3mph with a 2.379 60'. I can't seem to keep the wheel spin down, but I did do a little better once the weather cooled down. I finished up the night with a 14.83 @ 95.12mph with a 2.554 60'.
Here is the question:
What do you guys/gals suggest for improving my 60' times? Besides a lot of practice.
Rootus
Officially Addicted
Feb 8, 2003
6,659
Portland, Oregon
May 28, 2005
  • May 28, 2005
A 96-98 Cobra is one of the hardest cars to launch, in my opinion. You have a very small window of RPM to launch in, if you are below that you'll bog, above it and you'll roast the tires. I never did have much success with my '98 Cobra. Based on more recent experience, I'd suggest that you try launching at about 3000 RPM and ride the clutch out a little to keep it from bogging. I would call a 2.0 60' time on street tires a success.
Your trap speed seems low also, are you granny shifting? Even with a crappy launch you should see more like 100-102.
Dave
stevstum
130
Salem, Oregon
May 28, 2005
  • May 28, 2005
Dave
I realized on my last run that I should not shift into 4th and it was really pinging bad at the top of the RPM's all at the end of evey run.
Rootus
Officially Addicted
Feb 8, 2003
6,659
Portland, Oregon
May 28, 2005
  • May 28, 2005
Interesting that its pinging, I thought the N/A 32V motors had knock sensors. Bad gas, or perhaps just really toasty (does it always ping at the top end)? I'd shift at 7000 (maybe 6700 or so on the factory tach), you should cross the line at just under 6000 in 3rd.
Dave
stevstum
130
Salem, Oregon
May 28, 2005
  • May 28, 2005
I think the pinging is caused by the heat. I am going to put a bottle of octane booster in it next time just to make sure.
saleenster
2,621
Vancouver, WA
May 28, 2005
  • May 28, 2005
reduce your rear tire pressure to something close to 20-24 psi...and dont get excited! Roasting the tires is nice for the crowd to see, but it killz your et
Darkness
3,345
Banbury - England
May 28, 2005
  • May 28, 2005
Pffft forget about that crap, none of those octane boosters really raise the octane enough to make any difference. Just go to a paint store and get a gallon of toluene and put it all in a full tank of 92 and that will bring it to about 96 octane (more or less I believe).
As far as times you should see right around 13.5-13.7 on street tires....soooo practice practice practice. And for the launch dont use any rpms, just go off idle and as you release the clutch just floor the gas...this should produce a slight chirp of the tires and a very small bog, and ....voila.... there you have it, 2.0-2.1 60ft times. Hope it helps.
codemonkey
Hungrymonkey's helper monkey
Nov 4, 2004
538
Wilsonville, OR
May 28, 2005
  • May 28, 2005
Mine was pinging pretty good today too. It was nice meeting you out there! The stangs were taking over!
Today was my first time running this car, I managed a best of 15.26 @ 96mph, with 2.414 60'. I am not sure what was going on, but should have been doing much better. Other than not being able to hook up in the 60', I'm not sure what went wrong today.
A
agirlbeatyou
Burnout Queen
Feb 25, 2003
1,376
vancouver, washington
May 28, 2005
  • May 28, 2005
I raced woodburn on thursday:
temp 92
r/t .191
60' 1.885
330' 5.485
1/8 8.482
mph 83.36
1000 11.037
1/4 13.190
mph 105.04
That motor thats in my car used to be in our other f/b we raced, its best time was 12.7, it weighed about 300-400 lbs less then my car and it had 15' rims on it. So in other words I'm ok with my 60' but my 1/4 time should be better .. I NEED TO SHIFT QUICKER!! nonono: Ill see ya tonight!!
codemonkey
Nov 4, 2004
538
Wilsonville, OR
May 29, 2005
#10
  • May 29, 2005
  • #10
I agree. There comes a point where you just want to boost the octane enough to prevent detonation. I've seen cases where cars dyno'd better with 100 octane than 114. Friday, I ran 92 in it just to get a feel for how it was going to do, but in the past I've always run around 100 and done just fine.
Thanks for rubbin it in Mischa! I would kill for 13.1 right now, but I'll be seeing that by the end of the year, I'm determined.
That means you'll see more of my happy face up at Blue Oval!!
The Factor
1,485
beaverton,oregon
May 31, 2005
#11
  • May 31, 2005
  • #11
Just say no to roasting the tires I'd rather just smokem Were almost there Cory july 17 is around the corner
saleenster
2,621
Vancouver, WA
May 31, 2005
#12
  • May 31, 2005
  • #12
And I cant freaking wait! Going to work everyday for 10 hrs learning all day long is getting OLD!
Misha, 13.1 is darn good
ddonaca351
2,055
Camas Washington
Jun 1, 2005
#13
  • Jun 1, 2005
  • #13
Misc stuff....
- I disagree with Paul, I have had good luck with "104+" octane booster. (when I had iron heads)
- 100 octane should yeild more power than 114, as long as you have clean combustion (no det, no pre-ig) because of the slower burn rate of the 114. (imho)
- 13.1 dang.... I could get beat by a girl.
..........but she'll probably red-light.
DD
A
agirlbeatyou
Burnout Queen
Feb 25, 2003
1,376
Jun 2, 2005
#14
  • Jun 2, 2005
  • #14
DD
funny you mention that.. I have the plates on order..."AGRLBTU" no red lights for me on wednesday!!
A
agirlbeatyou
Burnout Queen
Feb 25, 2003
1,376
Jun 2, 2005
#15
  • Jun 2, 2005
  • #15
Thanks Cory, Yeah 12.9 is banging on my back door.. wait that sounds bad..
M
New from North Texas
  • MFReeves
  • Aug 26, 2025
  • The Welcome Wagon
The Welcome Wagon Sep 22, 2025
nickyb
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
SN95 Desktop 363 Engine Combination - Looking for input
  • WhiteCobra95
  • Sep 8, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 6, 2025
Habu135
M
  • mnky99
  • Sep 5, 2025
mnky99
M
H
Hello all from my shop, Tod/ Tods Hot Rods, located in Moorpark CA 93021. Longtime 25 Yr Restoration/Performance Shop and Custom Builder Owner. Tod
  • Hot Rod Tod
  • May 28, 2024
  • The Welcome Wagon
The Welcome Wagon May 28, 2024
LILCBRA
  • Community Forums
