Yeah, that's good advice if you're really squeezed for money. Freshing up the suspension is not a bad investment on a 13 year old car either.
There's not many small mods that will make a noticeable difference. A few extra degrees of ignition timing with my timing adjuster made the biggest improvement on my '96 among the few bolt-ons I've done - the downside is running premium gas now but it made a noticeable improvement from idle to redline and was really noticeable in the low RPMs where 95% of your time is spent while driving. They don't appear to be as popular as they used to be and I see a lot of people recommending skipping the T/A and getting a tune instead - that's probably not a bad idea as a good tune can be much more precise than simply cranking up the base timing. 96's have the least aggressive factory tune of the 4.6L Mustangs so either route will net you some decent gains.
A lot of people like underdrive pulleys too and I've got 'em but I'm not sure I haven't compromised alternator & battery life and possibly cooling capacity with them - on the other hand, I believe some models, like the Bullitt I believe, were under driven from the factory so maybe its fine. I didn't notice any performance difference with them though and probably wouldn't do them again but I haven't been motivated to put the stock pulleys back on either.
I've still got my long-legged 2.73 gears but having driven a couple of NPI 96-98s with 3:73 or 4:10 gears, shorter gears will make the car feel much livelier around town.
I'd skip the little stuff and start planning and saving for some sort of PI swap - intake & cams at least, if not a full head swap if you really want to get some more power.
