What cars can I get a 9 inch rear from if i were to look in a junkyard? I'm talkin about a rear end that i dont have to modify in any way, just bolt in. Could like a cougar or rear end work or any v8 mustang from 65-70? Just a list will do
candyapple said:You will also need to do alot of suspension work. Trust me, I am at that point right now. I just put in my 302 and found that unless I upgrade my supension, I cannot get a starter on the engine.
63_Fairlane said:From what I have heard, the early motor mounts are not supposed cause that kind of problem. Even with the one inch drop, everything is supposed to fit. However, the tolerances on these cars was not tight and the subsequent years of use probably haven't made them better. It may be simple tolerance stackup... each piece is off by a few tenths and it adds up to interferance.
In any case, it is something that I will look before dropping in a new engine.
A few questions Mosse and other folks with engine fit issues...
1. Does the car have a quick steer kit?
2. Is the oil pan stock or aftermarket?
3. Does the car have power steering?
4. Have the shock towers or any of the front sheet metal been modified?
5. Has the car ever been in a wreck?
6. Are the rubber portions of the engine mounts in good condition?
Any of these may effect the fitment of the engine. Thanks for any comments or answers.![]()
