What cheap mod next
85MustGT
95
Occupied San Diego
Well I have my 4.10s, chin spoiler on the way, shifter next month. After that I am unsure but here is my list but not in any order...
Pulleys - I have heard of problems at idle
CAI - I heard that 4.6 run better when cool
Timing adjuster - do you have to run premium gas
Throttle Body - any real gains on a stock motor?
Subframe connectors
Pinion snubber - DO these help you launch
I can't afford the PI heads and intake for some time yet, so no need to mention it.
:spot: :spot: :spot: :spot: :spot: :spot:
Pulleys - I have heard of problems at idle -- seem to be a good mod, but I talked to the guys at one of our local shops and they said they saw a max gain of 5 hp from them.
CAI - I heard that 4.6 run better when cool -- get the K & N filter and cut your airbox yourself
Timing adjuster - do you have to run premium gas -- not california legal but ya you gotta run premium
Throttle Body - any real gains on a stock motor? -- will help out a bit but not worth it unless you're supercharging the car
Subframe connectors -- DO IT! ASAP :) you'll feel how much stiffer the car gets
Pinion snubber - DO these help you launch -- wish i knew wtf these were.
those are just my opinions btw...
you might wanna look into control arms too :) they'll help you plant your tires better.
