What Degree thermostat ??
Busted07
I need my gorilla to be about an inch longer.
Nov 15, 2005
I did search, but didnt find what i was looking for because i have a carb'd motor now.
It has TFS aluminum heads, a 3 core radiator, Edelbrock hi flow water pump, and i wont have an electric fan for a while because of budget constraints. From the searching i did, a 195* is the way to go with EFI, but what about with a carb'd engine?
Thanks in advance for any help!!
Sometimes you gotta let op. temps decide what stat is used. If a 160 is what allows someone to stay at 190*F in the summer, that's alright for the time being. For someone with a mega cooling system, a 180 can keep a car at 185*F. In other words, I'd shoot for a target op temp and work on system efficiency if needed. A colder stat will help crutch lackluster efficiency until parts can be renewed.
MHO. Good luck.
MHO. Good luck.
Ok, in that case, what temperature do i want to stay under?? that will give me a good starting point.
As far as mileage and general wear goes, between 195-205* is where you wanna be. Going 215* or higher can give you some performance issues, but so can going below 185*.
I have to switch back and forth on mine and run a 195* T-stat in the cooler months and a 180* unit in the hotter months; when I run too hot, I get pinging problems, and if I leave the 180* in when ambient temps cool down, my gas mileage takes a dump. Of course, this is on an EFI setup, but on a carb'ed setup, it's going to be relatively the same. A cold motor is not going to run as efficiently as a motor at proper operating temp, but running too hot will hurt your performance, as well, no matter what fuel system you're running - that's more a matter of the properties of metal and friction than fuel delivery.
As stated, take into account the rest of your cooling setup and go from there. Even with a 3-core radiator and a big honkin' electric fan, I still need to run a 180* in mine to keep it cool in summer ... but then, I live in a desert climate where temps regularly go above 100* daily (ACTUAL air temp, not heat index, since motors don't know the difference between 100* in AZ and 100* in the Midwest). If your setup tends to run a bit hot in the summer months, I'd say shoot for a 180* failsafe t-stat. Otherwise, stick with a free-flowing or failsafe 195* t-stat.
And hey ... swapping T-stats on a 302 takes less than 30 minutes and a $2 gasket, anyways, so it's not like it's an expensive experiment. :D
Here is the answer...
As you get below 170-180F coolant temps, the wear on the cylinder bores gets pretty sketchy.
Best power and efficiency will probably be up around 190-200F, maybe a touch higher :shrug:
That is what I have seen in my reading anyway...
jason
MHO. Good luck.
170* summer --- 170* winter using the 160degree.... Now I didn't get a cheapy 5 buck crap from autozone either so watch what you buy, where you buy.
Now at the same time, don't go around believe what everyone else thinks, you wanna go with what works best. 160* keeps my engine a 170 constant but if you are in an upper atmosphere, then you may want something a tad hotter like Sicarius.... what kinda name is that anywas??? LOL
