Unfortunately a Clear tube (as C&L calls a sample tube with NO color code), has very little meaning. The clear tube is correct for a A9L, 73mm MAF, and 19lb injector. However since the color marking can be removed so easily, a tube without color
must be verified as appropriate.
I have been doing a fair amount of research on this subject the last few days, and here are the potential problems for you.
1. You need to verify that the MAS (just the black electronics box) is correct for a 93 Cobra. I was wrong when I stated that the A9L and X3Z MAS were the same. They are different due to the 93 Cobra having a 70mm MAF, and the A9L having a 55mm MAF. I will go out to the car in a few miutes and provide my part number as I have a cobra MAF. it may be best to call a Ford dealer to verify this though, as Ford has been known to change part numbers from time to time. Or, check here.
http://www.motorcraft.com/default.jsp
2. You do not know if your sample tube is correct for your C&L meter & Injector combo. Since there is no color coding on the back end of your tube you will need to measure it. A pair of calipers will do the trick. I have a list of common (on Mustangs anyway) C&L sample tubes listed with inlet and outlet diameters, on my website.
http://www.freewebs.com/vristang/clsampletubes.htm
Let me know if you have more questions
jason
