It's tough to compare your car to other cars...just because this guy's car weighs a lot more doesn't mean anything really. Your car weighs a good 3500lbs and it's gonna flex like a wet noodle which means crappy traction. Plus my guess was based off of your car being an AOD car, which i have no love for unless they're built and have a healthy converter that's matched to the engine and cam. If your car was a 5 speed it would be a different story, as well as if it were a hatch or coupe. Also from what i know about speed density is that it's only faster if you have a stand alone fuel management system like Megasquirt or something...otherwise if you put a cam in a SD car you're asking for problems. I would also assume that this Magnum likely has a superior suspension than us Fox cars have and probably gets the power to the ground much better....get some upper/lower CA's and subframe connectors and that'll make a big difference. Overall IMO, the lack of a stout converter and gears is what will hold you back from being a 12 second car...but that's just a guess. I've only ever seen one vert in person that was fast, and it was a 10 second car...it looked and sounded bone stock and the guy WOULD NOT lift the hood so nobody ever knew what he was packin, and it was a total sleeper.
