  • SN95 4.6L Mustang Tech
what exactly does...
  • Thread starter Thread starter 1of2000
  • Start date Start date Apr 26, 2005
1 of 2 Next Last
1of2000
36
Between the Appalachians and the Atlantic
Apr 26, 2005
  • Apr 26, 2005
...HOLDING THE PEDAL TO THE FLOOR WHEN STARTING YOUR CAR DO???
On about 1/2 of my starts, the car will just crank and crank and crank unless I hold the pedal to the floor, then she fires off... WTF? What could cause this, and what does the pedal actually do when you push it to the floor?
I have a Predator Chip with a custom dyno tuned burn. This problem started 6 months ago when this chip was first installed....and they don't seem to have answer for why??!
J
jegg
106
  • Apr 26, 2005
maybe you need a new fuel pump
9646gt
595
Holloman AFB,NM
Apr 26, 2005
  • Apr 26, 2005
Try turning the key on and off several times with out starting the car then start it..this will build fuel pressure back up by cutting the pump on and off ...if it fixes it try changing your filter and if that doesnt help it may be the pump..
F
ForPointSex
395
Mercer, NJ
Apr 26, 2005
  • Apr 26, 2005
It stops the fuel injectors from firing. It's used when you flood the engine.
hotmustang331
2,967
Bastrop,TX
Apr 26, 2005
  • Apr 26, 2005
Hmm, usually holding it to the floor will do nothing, BUT if its durring cranking it may start spraying gas from the injectors. I dont think you would be making 450RWHP if the pump or filter was bad...however it could be a problem with the system bleeding of fuel pressure. Do like the above poster said, turn your key to ON for about 3-4 seconds then crank.
1of2000
36
Apr 26, 2005
  • Apr 26, 2005
this sounds more like it. i recently replaced my fuel filter. i have the external Vortech fuel pump, and i had to replace my in-tank with a 255lph pump. So could it be flooding itself when the pumps fire up? <p>
should i fast turn the ignition all the way VS. letting the fuel pressure gauge come up normal (31psi)?
1of2000
36
Apr 26, 2005
  • Apr 26, 2005
see my last msg. this is what I do. I wonder if it is flooding the motor? Is this even possible??? <p> now that I think about it, this also started with the new intank pump... can you cram to much fuel in?? <p> i thought holding it to the floor was for old carburated cars??
hotmustang331
2,967
Bastrop,TX
Apr 26, 2005
  • Apr 26, 2005
Exactly, thats what you do when carbed cars get flooded, see when the car is flooded the mixture is TOO rich for the car to fireup...a bunch of fuel but no air...so when you push it to the floor it evens out the mixture, now it has alot of fuel AND alot of air then it will fire up.... but I dont think you could force enough pressure to make the injectors fire prematurly. The base idle could possable have been set too rich in that tune, but they should only spray when you start cranking, not when the key is on. This is weird...how does the car run after it cranks is there alot of gas smell and does the exhaust smell very rich?
starchman
73
Sheridan, AR
Apr 26, 2005
  • Apr 26, 2005
I may be wrong, but what about the IAC valve?
Mike97gt
it doe snot
10,633
the people's republic of massachusetts
Apr 26, 2005
#10
  • Apr 26, 2005
  • #10
this can be caused by the mixute being too rich for the car too start... with the throttle wide open your getting more air intot he motor making the mixture combustable..
you have a problem with your tune. i would run the stock tune untill you can get this fixed
1of2000
36
Apr 27, 2005
#11
  • Apr 27, 2005
  • #11
YES!
YES, it is extremely rich. And I have an idle problem (possibly the same problem?).
My A/F Ratio on the dyno is a fairly flat 11.5 but I thought this was OK because I am trying to keep the ponies down. litterally, I had to order the biggest pulley vortech makes to detune from 490!! So the big pulley and a rich tune holds her back for my stock block. Is this a bad idea? Can I just lean it out at idle/startup?
1of2000
36
Apr 27, 2005
#12
  • Apr 27, 2005
  • #12
I actually cleaned this out once, and grabbed one from the junkyard yesterday, but haven't swapped them yet.
I really think it's the tune...my car only has 50K miles on her...
jstreet0204
939
Winston Salem, NC
Apr 27, 2005
#13
  • Apr 27, 2005
  • #13
He has a supercharger and presumably larger injectors. The stock tune would make it run richer.
jstreet0204
939
Winston Salem, NC
Apr 27, 2005
#14
  • Apr 27, 2005
  • #14
1of2000 said:
YES!
11.5 is not too rich under WOT. Ideally you want to know what you a/f is at startup and cold idle. Check you plugs and see if there are any signs of running rich on them. You may also want to for fuel leaks, possibly around the injector seals
starchman
73
Sheridan, AR
Apr 27, 2005
#15
  • Apr 27, 2005
  • #15
Does it run OK once it has started, or do you need to keep your foot on the gas? If it runs fine, then it's probably not the IAC valve. When mine went bad I usually had to keep the throttle partially open (wide open when it REALLY needed to be replaced) for a while before it got warm enough to run normally. Of course, mine was nearly bone stock (K&N drop-in, silencer removed), so I didn't have any other possible issues like you have.
1of2000
36
Apr 27, 2005
#16
  • Apr 27, 2005
  • #16
Yes, after I hold it to the floor it fires up and warms up fine. the surging idle doesn't start until its at operating temperature.
ps - 42# injectors, lightning MAF, 255lph intank & Trex ext.
1of2000
36
Apr 27, 2005
#17
  • Apr 27, 2005
  • #17
good idea, I will check the plugs... what color is rich?
jstreet0204
939
Winston Salem, NC
Apr 27, 2005
#18
  • Apr 27, 2005
  • #18
black. If it was runing right they should be a brownish color
1of2000
36
Apr 28, 2005
#19
  • Apr 28, 2005
  • #19
Is this rich?
Let me know if the attached pix look like its runnin RICH?!?!
FYI: They are Autolite 764 plugs, and they only have about 500 miles on them. So I am not sure if the white means HOT or NEW?
jstreet0204
939
Winston Salem, NC
Apr 28, 2005
#20
  • Apr 28, 2005
  • #20
From what I can see in the pics they look ok to me. Try this, try starting it without hold it to the floor, so that it doesn't start but turns over several times, then check one of the plugs to see if it is wet with gas. If not I would start checking fuel pressure during start up.
1 of 2 Next Last
2000 GT-Front Brakes Not Releasing
  • stormsedge
  • Aug 7, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 7, 2026
Bronco2fan
D
Mustang not starting
  • Dawry Ramos
  • Sep 12, 2026
  • 2015 - 2023 Specific Tech
2015 - 2023 Specific Tech Oct 3, 2026
Dawry Ramos
D
M
2001 cobra ignition timing off
  • Mike3
  • Jul 13, 2026
  • SVT Tech Forum
SVT Tech Forum Aug 2, 2026
Mike3
M
P
2000 GT Random Power Loss
  • Pinellas50
  • Mar 9, 2026
SN95 4.6L Mustang Tech Mar 23, 2026
Pinellas50
P
Hard to start when engine is cold
  • 86_Capri
  • Mar 11, 2026
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 21, 2026
CAMTWO1070
