what grit emery cloth to clean up cam??
I use 1500 grit sandpaper lubed with motor oil. VERY smooth, polished surface while removing minimal material. Cut long, thin strips (lobe/journal width), wrap the around the lobe/journal, and pull back and forth so you exert even pressure across the lobe/journal face.
