What head gaskets for TF heads?
The 1011-2 uses a pre-flattened copper ring to seal the combustion chamber, no loc wires. I'm running ARP studs to bolt them down. Don't remember the P/N off hand, but I picked up the ones that TF recommended. So far, I've only put 5-600 miles on it with no problems, but I'm also afraid to blow up my already tired T5...
really? no problems? btw you live really close to me. (joliet)
I actually replied to a post in 5.0 Talk about having seen your car at JJC before.
I used the ARP 154-4201 studs that TFS recommended. I ordered them at Winner's Circle in Joliet because they were actually cheaper than going through Summitracing. The need for the bushings to step down from 1/2" to 7/16" is only required on certain part numbers for their heads. I ordered part number TFS-51400004 when I got mine, with the upgraded dual valvesprings that are good up to .600" lift and have 7/16" rocker studs. They're pre-drilled for 7/16" head bolts/studs with that particular part number. I think the o-ringed heads are the only ones that come with 1/2" bolt holes. I also used the stock alignment dowels as I couldn't see spending $9.95 on new ones when the ones I already had looked perfectly fine. Feel free to shoot me a PM or if you have AIM/AOL, send me an IM (fiveliterstang95) if you have any more questions. Hell, I'm 10 minutes away, I could lend a hand if necessary.
hmm, mine have dual valve springs and 1/2'' bolt holes, the seller said they have 3/8 rocker studs. ill have to go re-check that. but im pretty sure i have to get the reducer bushings/washers from trickflow.
they came in last night, clearly no signs of O-ring grooves.
and does that look like carbon buildup or JB to you guys? its only on one port, but its also on the valve so im assuming carbon buildup?
