WHAT IS YOUR MOTOR COMBO
Info on the coupe is in my sig, these dyno numbers are with my old set up of Cobra intake and GT40 iron heads. Haven't dynoed with the new set up which is Hogan upper and Trick Flow lowers. Hoping for better #'s. Also on this dyno sheet was with the timing locked out at 20 degrees, I have since installed an XPI timing lock box ,now the initial timing is set @14 degrees and when the box senses boost it locks @18 degrees, big improvement, and I think that will help produce some bigger #'s.
On my 93 Cobra I went with stock block, mid length headers, and Trick Flow Track Heat upper and lowers that got massaged by Ron Robart @ Foxlake, and that made 315/342 rear wheel, and with 410's it's alot of fun on the street.
Stock bottom end
E Cam
AFR 185's with the 1.53 OD spring upgrade
Professional Products Upper and Lower
24 lb/hr injectors
73 mm mass air
70 mm TB
1 5/8 BBK coated longtubes with 2 1/2" exhaust
MSD Digital 6 and billet distributor
320 wheel hp
Best ET/Speed of 12.71 @ 109 at Gateway in St. Louis
88lx
351w bored .030=357w
victor jr., harland sharp rockers and stud girdles
e cam
trick flow black intake, 3/8" spacer
70mm tb
u/d pullies
42lb injectors
msd pro billet distributor, msd coil, msd digi 6
hp stage 1 60mm turbo 10lbs intercooled
dont see why 600+ ft lbs. is out of the question
91 gt
bone stock down to the cats
306 10:1 comp probe flattop forged pistons. AFR 165's, PS3 springs and basic valve job, rest is stock; FTI custom cam (the heart of the combo) eddy rpm intake, scorpion 1.6 rockers, 24lb injectors, 65mm t/b, pro mass 24lb meter, moroso cai, march u/d pulleys (not running alt pulley) mac 1 5/8 unequal shorties, vrs o/r xpipe, mac catback, pro 5.0 shifter, 3.73 gears. All season street tires 1/4 run: 2.0 60' 8.2 @ 88 mph in the 1/8th, then 12.65 @ 110 in the 1/4. Street tires, no suspension work at all other than kyb struts and shocks.
Awaiting my bottle now so I can hear her giggle. Woohoo.
=Stock bottom end
=Edelbrock Performer 2.02/1.60 heads (slightly ported)
=1.6 rockers on the intake & 1.72 rockers on the exhaust
=E cam
=Edelbrock RPM II (slightly ported)
=BBK 70mm TB
=BBK fuel regulator
=Mac cold air
=underdrive pullies
=AC delete
=1 5/8" LT's (Mac I think??)
=o/r X pipe
It put down 299.9rwhp & 320rwtq on a dynojet untuned. It still has stock injectors, stock fuel pump, & a 93 Cobra Maf, so it did lean out a bit on the top end. I will be adding 24# injectors, C&L maf, & a 255lph pump soon. Due to the huge manifold, it isnt much on the low end, but pulls like a raped ape from 4000-6000, even with crappy 3.08 gears. Once I build a bottom end, I will install a better cam, but with the 2.02 valves, PTV clearance is slim, so anymore of a cam would cause problems...
Stock block, Scat 331 stroker crank and rods, DSS main support, Ross 8.5:1 pistons, Comp Cam, J-302 Heads, Ported GT-40 Lower, Comp Cams Roller Rockers, 42 lb/hr injectors with custom fuel system, water meth injection, Kenne Bell Supercharger, Flowzilla inlet with bypass valve, 90mm t-body,Long tube headers, Canton Road Race oil pan, electric water pump, no a/c, no p/s, ATI dampner 28 oz imbalance ect. ect.
My mods are pretty basic:
C&L 76mm MAF/CAI kit, 75mm TB, ported stock upper/lower intake, ported/milled E7's, Crane 1.7 RR's, stock cam, MAC LT's, custom offroad H-pipe, straight-thru mufflers, ASP u/d crank pulley, EGR/smog delete, 190lph fuel pump, BBK AFPR set at 45psi, stock 19lb injectors.
