What kind of drive shaft? C4 in Fox Body
as long as the aod driveshaft was from a v8 it will/should work for the c4. when i did the v8 conv on my 92 i reused a t5 driveshaft from my old 89gt and it fit perfect. only thing you will need to do is grind the tac welds of the trans crossmember and slide the flat part all the way forward to get the trans mount to drop in the hole. other than that easy going.
