what mod
  • Thread starter Thread starter 93notchspray
  • Start date Start date May 20, 2004
9
93notchspray
87
blacklick ohio
May 20, 2004
  • May 20, 2004
im stuck on what mod to do next. im thinking about a cam or throttle body. which one is better for the buck? i have alot of mods already, but my car feels slow. i have cai pulleys adfpr headers smog delete electric fan x-pipe flows edelbrock rpm intake 190 pump 410s and 150 shot of spray but it just feels slow. help decide. iwas thinking of the b cam or a 70mm throttle body. also what fuel pressure do you guys run? and i have 10 degrees timing now will bumping it up to 14 make a huge difference? thanks jason
powershift351
225
Carlsbad, Ca.
May 20, 2004
  • May 20, 2004
the timing bump will make a diff. What MAF and injectors do you have?
powershift351
225
Carlsbad, Ca.
May 20, 2004
  • May 20, 2004
also, be carefully hitting the nos with the timing advanced so far
houstonstangguy
979
Houston, Texas
May 20, 2004
  • May 20, 2004
if you are still running the stock heads then I might wait until the head swap to do the cam personally. go with a 65mm throttle body and 1.7 or 1.72 rockers. they are cheap and you will need them anyway.
i also agree on the timing advance with the spray. you running cooler plugs or what?
next i would concentrate on the heads because the stock heads are only corking up the combo.
oh and get used to it feeling slow. it is because you are used to it. no matter what you do in the future, at some point you will get used to it and it will feel slow again. it is just the way it goes in this hobby.
9
93notchspray
87
blacklick ohio
May 20, 2004
  • May 20, 2004
i have stock injectors and maf. so you guys think i should wait till i get heads before i mess with a cam. i am running two stage cooler plugs now. i have never ran car with timing at 14 just at 10. it went 13.98 with a 2.00 60 ft. but i think there is alot left in it, thats motor also. i want to be at the 12 teens range soon so any tips would help. thanks jason
88stangmangt
2,332
Stafford,VA
May 20, 2004
  • May 20, 2004
look into thumpers heads for 700 they put people into the 12's N/A. just nice ported e7's with a 150 shot you should be in the 11's easy.
houstonstangguy
979
Houston, Texas
May 20, 2004
  • May 20, 2004
true about the 12's but most people who use thumper heads either buy a package with a cam, or they already have a cam.
he sells packages with the b, e, or custom cam.
you might ponder some 24's and a 70, 73, or 75mm mass air meter too.
BnGRacing
51
Chicago area
May 21, 2004
  • May 21, 2004
When was the last time you re-packed your LSD? Also what have you done to your suspension? Cheap azz tires are also a no-no. Recent tune up or a dyno tune? Check the simple stuff first...its always better to error on the conservative side.
9
93notchspray
87
blacklick ohio
May 21, 2004
  • May 21, 2004
i dont have cheap ass tires i have a brand new set of et streets on monoque d-5s with drag shocks and struts.
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
Surging/stalling! problem or tune?
  • djj62478
  • Oct 4, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 14, 2026
KRUISR
Engine Stalls when downshifting/coasting
  • Scott_S
  • Nov 5, 2025
Fox 5.0 Mustang Tech Nov 6, 2025
Mustang5L5
Fuel ‘88 GT Runs Rich Cold — Fixes Itself When I Unplug Sensors (ECT, MAF, O2, etc.)
  • Sufarry
  • Nov 6, 2025
Fox 5.0 Mustang Tech Nov 9, 2025
Mustang5L5
A
Discussion on mild budget build/ top end
  • Acesario
  • Feb 21, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 23, 2026
General karthief
