  • 1994 - 1995 Specific Tech
What point to go to billet flywheel?
  • Thread starter Thread starter 94-302-vert
  • Start date Start date May 19, 2006
94-302-vert
1,947
NE CT
May 19, 2006
  • May 19, 2006
Ok, clutch time is darn near...
For the flywheel, Billet or nodular Iron?
At what HP or RPM limits should you not use a stock replacement flywheel?
Thanks!!!!
Therian
The Highlander
Waterloo, Ontario
May 19, 2006
  • May 19, 2006
I believe the clutch will typically give out ahead of the flywheel...if you're using the HD or KC I assume that would be somewhere in the ballpark of 400bhp. So unless you're doing some heavy forced induction, the iron flywheel should be able to withstand the power. I never really saw the benefit of the billet flywheel when you could just move to aluminum for 60-70 dollars more. Somebody correct me if I'm wrong
BPA
159
S.F.
May 19, 2006
  • May 19, 2006
if its lighter it might help you rev up faster
W
wytstang
Mustang Master
Mar 14, 2004
4,988
Summerville,SC missing South Fl. weather :(
May 19, 2006
  • May 19, 2006
600+fwhp thats what DDperformance.com said IIRC. It was high before they recomended using something other the the ford flywheel. Since the Walshes are drivtrain specialist I listen when they speak. .02
Grn92LX
Fidanza Man!
6,819
64
129
New York
May 19, 2006
  • May 19, 2006
I needed a new flywheel for my combo since its a 28oz balance. I went aluminum for the obvious benefits.
If you have the money go with a fidanza aluminum flywheel. They come with different weights so you can interchange it with different engine imbalances.
There isn't a hp # that tells you its time for a new flywheel.
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jun 20, 2026
gray owl
G
Quick question about flywheel.
  • 2003 mustang gt modded
  • Jun 16, 2024
1994 - 1995 Specific Tech Jun 24, 2024
AeroCoupe
Hello Everyone !
  • 5150K
  • Jul 3, 2026
  • The Welcome Wagon
The Welcome Wagon Jul 3, 2026
5150K
  • D Durden
  • Oct 20, 2025
  • 2 3
3K
Car shakes when taking off help???
  • STANKYstangs
  • May 10, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 27, 2026
LILCBRA
