what rear end
  • Thread starter Thread starter 65inworks
  • Start date Start date Oct 16, 2004
65inworks
101
sacramento,ca
Oct 16, 2004
  • Oct 16, 2004
what rear end would you put in a 65 mustang that is pushing around 330 to the wheels. right now it has a stock 8 in and a t5 tranny. thanks Nick
latamud
791
Tampa, FL
Oct 16, 2004
  • Oct 16, 2004
An 8 will be fine for 330, no problem. I'd look into upgrading to a trac loc with better gears though.
J
John Z
581
Morgantown WV
Oct 17, 2004
  • Oct 17, 2004
Many believe the 8" is good to about 400 hp depending on the type of transmission and tires. I'm not questioning this "conventional wisedom". However, Ford upgraded to the 9" with the hipo (271 hp) and all large blocks. Apparently Ford did thought the limit for reliability was somewhere south of 270 hp.
HistoricMustang
2,359
Confederate States of America
Oct 17, 2004
  • Oct 17, 2004
GoogleMan..............You will be history before too long.
A well prepared 8" will handle 330 rear wheel HP.
HistoricMustang
www.historicmustang.com/tech.html
F
fastback brian
540
So Cal , I.E.
Oct 17, 2004
  • Oct 17, 2004
If you have a factory stock 65 8 inch then you are not gonna make it too long. Atleast a set of 66 axles and a 67+ case, mini spool and a granada housing. There is just about nothing on the 65 8 inch that is any good for handling power. I would start shopping for a 9 inch or atleast a maveric or granada 8 inch to build.
latamud
791
Tampa, FL
Oct 17, 2004
  • Oct 17, 2004
If you can afford it its alway nice to be over prepared. A 9in is going to hold up to abuse more than an 8" in most cases. If you want to keep the 8" and not bother with hunting for a 9" and getting it sized for your car then you'll be okay. Ford liked overkill, putting a 9" on 271 hp is that. But, it leaves room for more hp.
G
GaPonyFarm
663
Columbus, GA
Oct 17, 2004
  • Oct 17, 2004
I wouldn't change it, unless you break the 8". I'm one of those who think the 8" is good for more than 270. If you're needing to change gears and such anyway, go ahead and get a 9" trac-loc with 3.55 gears. Stay away from lockers and spools. You won't like the ride, if you do mostly non-drag strip driving. If you're buying new, go ahead and get 31 spline axles instead of 28, since they cost the same.
rbohm
6,698
550
204
tucson,az
Oct 18, 2004
  • Oct 18, 2004
the 8" will be just fine untill you get to the 350+ mark with slicks and the 400 mark with out slicks.
D
D.Hearne
11,730
south louisiana
Oct 18, 2004
  • Oct 18, 2004
As far as I know, both the 8" and 9" use the same axles ( if the 9 has 28 splined axles) so what makes the 65 8" alxes so fragile?
blue66tang
1,092
Medford, OR
Oct 18, 2004
#10
  • Oct 18, 2004
  • #10
the 65-66 axles tapper down in the middle. If you slide one out you can totaly tell.
I would sugest saving money for a 9". You will probobly be ok for a while, but eventualy it will break. It actualy might be fine for ever if you limit the riders to 2. I had 4 people in my car when i nailed second gear.. BOOM! So now i have a 9".
65inworks
101
sacramento,ca
Oct 18, 2004
#11
  • Oct 18, 2004
  • #11
what about a late model 8.8 in. rearend. who has used those and what did u think?
bmcelhinn
64
#12
  • Oct 18, 2004
  • #12
The new DPI Black Gold street 9" is the best differential I've experienced in a mustang.
12sec67
1,301
San Diego, Ca
Oct 19, 2004
#13
  • Oct 19, 2004
  • #13
i beg to differ
i have broken 1 housing, 2 sets of gears professionaly installed and shattered 1 auburn locker, and bent an axle all with a little 302 and street tires.
---- see sig
D
For Sale 1993 Mustang LX for parts or restore
  • diesel farmer
  • Oct 6, 2026
Fox Body Mustangs For Sale (1979-93) Oct 6, 2026
diesel farmer
D
Brakes 80 Mustang 4.2 rear chassis brake line for 5 lug conversion!
  • StangPowerLSX510
  • Aug 6, 2026
Fox 5.0 Mustang Tech Aug 9, 2026
limp
N
1969 15x10 295's for rear. Modifications needed?
  • normg
  • May 1, 2026
1965 - 1973 Classic Mustangs -General/Talk- May 2, 2026
GypsyR
G
A
90 Fox 4Lug rear convert to 5 Lug
  • adimice
  • Jun 3, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 6, 2026
limp
K
3.8 T5 & Bellhousing to 1987 Lincoln 5.0
  • ks65stang
  • Mar 2, 2026
  • Other Auto Tech
Other Auto Tech Mar 3, 2026
