Hello everyone:
I am currently new to this site. I have a 95 5.0L which I have had stored away for 5 years. Before I stored the car away I added some modification to it which include:
GT40 Crate Engine
Built AODE transmission w/ 2800 stall converter
30lb fuel enjectors
Modified mass air flow sensor
Trick flow upper and lower intake
Cold air intake
Bassani X pipe
Flowmaster 2 stage cat back.
Now obviously , there are some bits and pieces that still should be added. All I want to do is get the car to run smothly on the road (for now).
I am having a few problems,
1.) the brake petal is hard as a rock when the RPM's are low. My brake booster is running fine, so I don't know what the problem is. This occured right after the Crate Engine was installed.
2.) When I let off the accelerator going about 30mph the car tends to jump (it feels like somone who doesn't know how to drive 5 spped is driving it)
Those are really the only two problems. I come to you for suggestions.
I know I need a bigger throttle body, and probably an adjustable fuel regulator. Any suggestions on anything else that is a MUST. Again all I want is for the brakes to work and for the car to run smoothly on the road. Any help would be appreciated. Thanks for your time.
GT40 Crate Engine
30lb fuel enjectors
Cold air intake
Bassani X pipe
