What size tires for 17 x 9, 17 x 10.5 wheels?
Zorro
294
LOS ANGELES
I'm debating how wide I want to go in the front. I dont' know if 275 in the front might be too wide causing tracking. I know for sure I want 315 in the rear. What sizes do you recommend. Is it 315/35 in the rear or 315/40. How about the fronts? These will be going on bullits by the way. Thanks for the help.
I have 275/40 Nitto 555's up front and aside from a slightly reduced turning radius and minor rubbing on the fender liner I am happy. I have Steeda Sports though, so if you arent lowered you probably wont have any problems. Also, if you go 315's it may run on the tailpipes, quad shocks, and fender liner. Just so you know, but its easy to fix with a hammer. :)
I'm putting a set of the deep dish bullitts on my car as well, and in the same boat needing tires. I have a vert, with 315 still fit NO PROBLEM? If theres any chance of problems, what would be the correct size down? I down really feel like fooling around trying to put 315s if sometimes they have rubbing or fitment issues.
Anyone have a picture of 315s on a 99+?
Def. a 315/35 for the rear. This size will also fit a vert. I have a 295/35 on the rear of a vert with an 18X10 rim and I plan on upgrading to a 315/30/18 soon. plenty of clearance!
