what sizq bolts to remove driveshaft
If you are decently strong, put the car in gear and e-brake it and break one or two loose. Put in neutral, spin the DS and do it again. I use a 3/8" ratchet.
Some folks loop a couple box end wrenches for leverage. Some use their leg on a breaker.
Be sure to apply threadlock to the bolts upon reinstallation.
Good luck.
Good luck.
Yup, 12pt 12mm.....Sometimes, depending on the driveshaft angle, a socket plus extension will not work. You will need a closed end wrench for it. Any 12mm combination wrench should work.
And definately put the threadlocker on the ds bolts, John (Zero Signal) found out what happens when you don't (clangity clang clang....)
Scott
Scott
I am sure he is gonna love that shout out. :D
final5-0 said:
Those bolts are coated with thread locker from Ford.
Just heat em up a bit and they come off with ease.
I've seen many say they broke wrenches trying to bust em loose, lol.
Later
Grady
True true and good advice. :nice:
